Hi
I thought I would put up my findings from looking into fitting a short nose R200 LSD into a long nose diff, After looking on the net I didn't find all the info I was after
The centre will fit etc, the problem is one of the R30 axels are to short to engage the LSD on one side, to use the short nose axel flange setup you will compromise the oil seal as they are a different diameter by a few millimetres.
My conclusion was to make it work I would need to spend some time on the lathe modifying the shaft etc and cost as much as a aftermarket centre. I decided to go with a Quaife centre and cost the same amount with no stress.
Enjoy
Steve
Was this using mr30 trailing arms? or hr30?
I'm also assuming you're talking about a factory viscous LSD too?
Viscous LSD's are mostly old and worn out now anyway, so I wouldn't bother with one.
But I can't see the oil seal problem being a costly issue. Was it possible to use the short nose seal in the long nose housing, to match the short nose flanges? If not, then turning up a pair of new oil seal rings for the short nose flanges shouldn't cost much. My local machinists would charge $50 or less for that.
If you are using mr30 trailing arms you will need to change the flange on there to match the larger cv's, either 4 bolt hr30 or make a 5 or 6 bolt one to match short nose cv's. Then use 4 x inner cv's with the appropriate flange on either hr30, z31 or custom shafts.
My conclusion is that it is possible with a bit of mucking around but only worth it for the right LSD center, I wouldn't bother with a viscous for any diff.
I was playing with a R32 clutch type centre with Z31 shafts, it is posable but I decided it wasn't worth my time. I thought I might share the finding as I wasn't able to get this info on the net. I just like to do things the long way around first then invest in good parts when I have had enough.
i was going to do the conversion my self but ended up buying a Cusco mz lsd from import monster for 500 fits the factory r200 cv from a dr30
model LSD162, only thing u need to do i to buy some reduces for the crown wheel holes from 12mm to 10mm but thats easy
  • 3 months later...
Hey guys.
im doing a track day in my dr30 on sunday and my longnose r200 lsd has decided it wants to be 1 wheel drive! i have to pull it down tonight but i belive it is a nismo or cusco lsd (not fitted by me) if this is the case i naturally dont want to weld it! if its standard i may?? the reason im posting this here is that i have a ca18det shortnose lsd with shims complete and im trying to figure if there is someway i can use it? if the centres fit can i just weld the ca diff and use my r30 cv shafts? please give me some direction as diffs in general are far from my strong point!
as far as im aware every dr30 long nose is lsd, when mine started to peg one, i just replaced the original clutch packs, and added a extra four, theres a spacer in the hemi u remove to allow this, been working fine for a few years now, pre load was around 85 f/p by memory.
stwewart wilkins sells the upgraded ones btw
i looked at doing the same thing lots of stuffign around
ur better of going on import monster u can buy a Cusco Rs or MZ second hand center that fits factory R30 r200 cv for like $600 dleivered
ok so i took it apart tonight.. its a mechanical 2way unsure of brand?? the two outer most clutch plates on both sides have a concave bend to them which seemed odd (i was going to reassemble those plates the other way around..) other than that there appears to be no damage to it which is a little curious im lead to believe i may have the wrong oil in it (this all started when i changed the oil) anyone know what a mechanical 2 way should run?
and any other feed back and tips? anything i should look out for?
its not hard to set up a diff as long as u keep ur shins just like they came out and u dont stuff around the the pinion
So you have a VISCOUS LSD you have brought in from Japan for $600.00 and you're putting it in a long nose housing?????????
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
