Regardless of whether you get the 3-way Mongoose M80G or Viper 855XV (or any other, which conform to AS), certain options will be on offer.
a) remote boot release - I'd decline due to likelihood of cable stretch
b) automatic door lock upon start-up - I'd accept if there's a chance of carjacking in areas you'd park or drive
c) auxiliary circuits eg. for turbo timer and others.
The alarm box itself though, you may prefer to ask the installer to place it in an obscure position.
Go see sam or brett @ phatt audio concepts in braeside , they do great work and know skylines
Tell brett troy sent ya off sau
Dont get turbo timer hooked up its a defect and ghey , gps tracking is advised if your budget allows
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
