Hi boys and girls just wanting some opinions on a body kit. Im getting a sunroof installed and decided that I would do a whole makeover at once, respray, bodykit and sunroof. I was looking at the do luck front bar, final conexion rear and side only because there are only 2 bodykits for the 4 door that actually look good, or the 400r front bar which one is better.
Edited by scotty boi
https://www.sau.com.au/forums/topic/407373-which-body-kit/
Im looking at getting some rays wheels soon just got to get the cash together and not sure what looks the best on R33 s anyone that has rays wheels or somthing similar please share photos would love to see them, cheers.
https://www.sau.com.au/forums/topic/407373-which-body-kit/#findComment-6495647
dude stop being lazy, and just google it.
a billion people have rays rims on R33's
https://www.sau.com.au/forums/topic/407373-which-body-kit/#findComment-6497641
"Photography" subforum > "R33" thread & Bob's ur uncle
https://www.sau.com.au/forums/topic/407373-which-body-kit/#findComment-6497856
That makes me want a 33 4 door
That is bad right?
Not when they look like that!
Who ever owns that one has done a damn good job. Good stance, beautiful paint, and the kit is well put together. In saying that though, I haven't spoken fondly of too many four doors at all.
https://www.sau.com.au/forums/topic/407373-which-body-kit/#findComment-6504057
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
