So I received my replacement fusebox sticker that translate into English today. Just wanted to show some of you guys who are still sporting the stock sticker.
Sticker Translated
Original Panel sticker
Using a hair dryer, I got the original sticker off nice and easily. Came off quite clean, no left over sticky residue.
The job finished.
Anyone interested in getting this sticker, you can pick it up from Street FX or their eBay store here for $7:
http://www.ebay.com....984.m1497.l2649
They've got all sorts of translated fusebox stickers including R32, R33, Stagea, S14, S15, 200SX etc.
No I don't work for them or this is a sponsored post. Just happy with the product :)
  • 1 year later...
Got one too, asked if the did the under bonnet fuse/relay box, but they don't. They told me if I could get it translated for them they'd print them. Any possible help from the missus Terry?
If anyone is searching for R32 under bonnet relay box sticker, there's an English picture in the R32 GT-R English workshop manual (which may be useful, print out and stick it on lol or get someone to make stickers from it).
But that fuse cover sticker is brilliant. Thanks for the share!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
