Shaved head, piercings, covered in tatts, both arms, back, chest lol
I've shaved the head right back a couple of times, got 4 piercings on my ear/face, one tatt on shoulderblade..but you win :P
Lifts kettlebells in Ugg boots. lol
Kicker right there ladies and gentlemen.
6'6" and 160kg. He's 21yo and had his first ever session on June 8 2010
He failed a 40kg x 5 bench press that day, only got 4. He weighed 105kg
He now squats 300kg, bench presses 180kg and deadlifts 300kg
Those figures are just obscene.
The best motivator for improvement is competition
The highest level of competition is Worlds
If you cant make big improvements going to Worlds, may as well hang it up now
Tolga, Max is now 89kg in the morning, he wants to lift in the 100kg class next year
Jacks improvement has come about because of his 55kg weight gain, plus not missing workouts
Yeah Jack is obviously a bit of a unique case, his genetics are obviously near on PERFECT for powerlifting. Normal people don't get that huge and that strong. He's gifted, that's for sure.
I'd love to get into competition, but since I ultimately lift weights for appearance reasons, I can't make the time for competition regimes :(
Spiros, Emad and Max all hit PB's today, 17 days till they lift at Worlds
Spiros squatted 230kg, Emad squatted 232.5kg and Max squatted 250kg
Nina and Amanda both hit bench PB's, theyre off to worlds as well
Amanda benched 67.5kg and Nina benched 77.5kg, thats 2.5kg above her own WR
Had 5 new people join the gym this week, strength is on the rise
Waiting for Nick to do a Saturday morning session, best session of the week
Me? not sure I can hang with those boys! what's the go on Saturdays? I could really do with some coaching...
That squat from Max was soooo smooth, serious power
How much does Emad weigh? bloody strong for a lean bloke!
So in an attempt to get stronger out of the hole I setup the pins at the very bottom squat position and did dead start squats... I attempted the PPP program in this fashion but it was not happening... had to drop 10-20kg off each lift! ... bloody hell its hard with no bounce
Then bench, going well, trying to practice the pause
Then straight leg deadlifts standing on blocks... stretch those hammies! I can barely touch my toes:/
Dips / face pulls
good session
already feeling better/stronger... even pinched some protein powder off my old man
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
