I'll have to ring abc and talk to them.
I have found a few different bars on this website:
http://www.gymandfitness.com.au/6-foot-olympic-barbell-commercial.html
There's a 2m womens cross fit bar on there as well which has the length taken from the sleeves, but it's pretty pricey.
The one I linked to says its got 1230mm worth of shaft between the inner part of the collar, but I have asked them how much room for plates there is on each sleeve. Don't wanna sacrifice to much weight plate room if I can get away with it.
So I may have to step up to a 2m bar instead of 6ft.
Thanks for your help Markos.
Yeh i get that part, but I don't need 1310mm between the inner edge of the collars. Just bigger than 1150mm so it'll work with my rack.
So the ideal bar would be 6ft long, have like 1200mm between collars, thinish collars and then be able to maximize sleeve length.
I should just knock down the wall so I can go a full size bar, but that won't go over well with the owners of the place haha!
I think you will struggle to get a decent amount of space on the 6ft bar. When I bought my rack I had a 6ft bar, it would fit in the rack but there was only about 20mm from the bit where the plates sit up against to the J-hooks - not very good when trying to rack quickly.
Edited by Dani Boi
Ok, ordered the bar.
The other thing I need to sort out is the rubber flooring for where I will be doing my lifting. I will be doing deadlifts, power cleans, front squats and maybe some snatches etc once I get my technique down.
I was thinking about just getting 1 or 2 of those 15mm commercial gym floor rubber tiles that are 1m x 1m. Then cut them in half and have two 50cm x 1m long strips about 1.1m apart.
Do you guys think the 15mm rubber tile over a concrete slab will be thick enough for dropping bumper plates onto from shoulder height? Or should I put one ontop of the other and have it 30mm thick on each side? I would like to keep the bumper plates and my bar in good condition.
Then I'll just get some ply wood that is 30mm thick and put it down on the concrete slab in between the tiles and have my own portable platform of sorts.
I would go all out and build a proper lifting platform, but I need something that can be broken down easily and moved/stored without takin up a lot of space.
Edited by Mitcho_7
just for those interested.
A group of people from Aus went to the GPC WORLDS competition in Slovakia.
There have been over 10 medal winners with a bunch of them being Gold.
Main one so far, the Owner of PTC Brisbane Scott Wasson has set 2 World records (1 for deadlift and 1 for total) and 4 Aus records (squat, bench, deadlift and total) and won Gold.
Scotts WR total (724.5kg - 257.5 squat, 165 bench, 302 deadlift) is an all time biggest total 90/93 raw in any fed in oz
Some of the bigger fellas lifting today.
If anyone is interested in watching the live feed you can here...
http://www.powerlifter.cz/live/
It should be starting about 4pm AEST.
I'm sure Markos will have more info and vids/pics etc when he returns
Edited by TTT
awesome effort, what a beast! must be the beard... I'm hoping mine gives me a few extra kilos
was watching the girls on that feed yesterday... in my limited experience the judging seemed very lenient, anyone who knows their stuff care to comment?
was inspired so last night we did: squats, Bulgarian split squats, good mornings, bench press, DB overhead press, cable chest press/flyes... completed in just over an hour... I'm tired today lol
Yeah Nick I thought the same about the judging from what I saw.
the press calls were REALLY quick too.
The judging is ALOT more strict at GPC Aus.
Couple of Brisbane fellas lifting today
Zach Turner - 140+ kilo, 19 year old, squats over 300kg, benches 180ish, dead around 250
Ricky Goodyear - around 105kg - 37 years old, he is opening on 300/190/290
yeah I really don't know enough to have an opinion either way, but it does get a bit confusing when your new to the sport
Those numbers are funny looking at on screen, your like yeah sounds impressive... but to actually load that shit up on a barbell and get underneath it... fck me
thing is, because they use proper thin metal 25kg plates, it doesn't look like much either
Compared to say bumber plates or the chunky shitty rubber coated plates that most gyms have (and I have at home).
Until you see the bar bend... lol
especially in the deadlifts, they use a texas deadlift bar which has some flexibility to it.
when loaded up with the likes of 300kg, there is a fair bit of bend in it.
The texas bar has a *lot* of flexability. I can feel the difference around 100kg off the floor.
By the time you get to 200kg the sides leave the ground significantly later than the middle, and it gets worse as you add more weight :)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
