see how bad the damage is from the scan. Determine If surgery is needed or not.
2-3 physio sessions a week to start with, stretches once 'healed' and then back into movements like running.
Start back into squats etc. once I get the ok. See how it goes
Depressing really, I feel I was makin good progress
Edited by jangles
Thats his heavy stuff done till States. He should total 650kg. This time last year I was lying in ICU so Max couldnt compete as he ran the show, he was at around 550kg. Before Nats he got injured, he was aiming for 600kg. At Worlds he got 650kg.
This year he is starting 100kg up. He plans to total around 725kg this year. The Junior WR is 690kgin the 90kg class.
At Worlds he weighed 86kg in the 90kg class, didnt have to make weight, in fact he's never had to make weight, lifting too light. 3 days before weigh in he was 84kg, he could easily have lifted in the 82.5kg, but he doesnt change plans midstream. He is currently 89.2kg in the morning.
By Nats he will have to make a decision as I reckon he might be 93-95kg, cut or lift in the hundreds, he's not fond of cutting, but he has definite plans and goals
he's very patient and focused... I'd back him to be over 700kg this year for sure
I trained yesterday at PCYC and had absolutely nothing... probably pushed myself a bit too hard, the stuffy nose and high temp came back last night... stupid cold has completely zapped me... still plenty of time to fully recover before states though... hopefully I can do some more quality heavy stuff this week, I'd like at least another sessions practice in the knee wraps
no excuses, I'll be ready come comp time and nothing bar a freak natural disaster is stopping me from a 200+kg squat
then 600+ at Nats..................
He weighed 77kg at the ProRawQualifier, benched 150kg
Today he weighed 83kg, benched 157.5kg
A few weeks ago he benched 80kg x 24, bodyweight
He actually filmed it for this website, I told him I wouldnt post it up, so he deleted it
    • Mount some of these on your dash? https://www.greddy.com/products/16001720
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
