2013 GPC Vic States
WOMEN
48kg class
1. Melissa Knight - 47.7kg - 85/47.5/110 - 242.5kg
60kg class
1. Rebecca Gleich - 57.8kg - 120/67.5/150 - 337.5kg
2. Sussy Kollen - 57.8kg -110/72.5/120 - 302.5kg
3. Vicki Jewson - 57.7kg - 90/57.5/130 - 277.5kg
67.5kg class
1. Heidi Stewart - 60.6kg - 110/70/150 - 330kg
2. Megan Reily - 65.4kg - 100/BMB/130 - BMB
75kg class
1. Jay Jama - 71.0kg - 60/30/95 - 185kg
82.5kg class
1. Emma Bortolotto - 81.9kg - 130/67.5/140 - 337.5kg
MEN
56kg class
1. Marlon John - 54.8kg - 115/80/120 - 315kg
67.5kg class
1. Jesse Markopoulos - 66.8kg - 160/100/190 - 450kg
2. Luke Bender - 66.0kg - 110/100/200 - 410kg
75kg class
1. Emad Nayef - 74.7kg - 235/115/255 - 605kg
2. Robbie Tissera - 73.1kg - 227.5/120/220 - 567.5kg
3. Ivan Ho - 70.7kg - 165/120/170 - 455kg
4. Dim Papaconstantinou - 70.5kg - 145/100/185 - 430kg
5. Daniel Distefano -69.5kg - 125/100/160 - 385kg
82.5kg class
1. Martin Nguyen - 80.9kg - 252.5/157.5/275 - 685kg
2. Eddie Dargham - 81.2kg - 185/105/250 - 540kg
3.Chris Van Gunst - 78.3kg - 150/125/235 - 510kg
4. Jordan Zollo - 82.4kg - 150/130/200 - 480kg
5. Sam Boyce - 81.3kg - 140/112.5/185 - 437.5kg
6. Dimitri Jayaratne - 76.7kg - 135/57.5/175 - 367.5kg
7. Adrian Zwaan - 81.9kg - 95/80/160 - 335kg
8. Krit Barnett - 82.0kg - 130/105/65 - 300kg
90kg class
1. Max Markopoulos - 89.8kg - 260/155/250 - 665kg
2. Adam Lam - 89.3kg - 240/140/260 - 640kg
3. Erros Chiodo - 88.0kg - 215/125/275 - 615kg
4. Nick Edlin - 88.8kg - 210/132.5/240 - 582.5kg
5. Keng Tan - 89.7kg - 215/142.5/220 - 577.5kg
6. Conor Zyskowski - 87.0kg - 230/110/230 - 570kg
7. Stelian Tchapkanski - 89.9kg - 180/150/215 - 545kg
8. Ethan Perera - 87.3kg - 130/80/150 - 360kg
100kg class
1. James Jenai - 94.5kg - 245/175/250 - 670kg (180kg 4th BP)
2. James Visciglio - 97.9kg - 195/135/272.5 - 602.5kg
3. Nick Haralambopoulos - 97.6kg - 185/120/250 - 555kg
4. Wayne Kollen - 99.8kg - 200/130/225 - 555kg
5. Josh Rayson - 96.9kg - 185/120/220 - 525kg
6. Kris Baldry - 99.7kg - 200/105/205/510kg
7. Ronnie Chau - 94.6kg - 170/100/242.5 - 512.5kg
8. Ross Katsambis - 97.7kg - 170/105/215 - 490kg
9. Jake Clinch - 95.1kg - 70/140/75 - 285kg
10 . John Nichols - 93.6kg - 80/75/75 - 230kg
11. Aaron Scarborough - 96.6kg - 80/80/65 - 225kg
110kg class
1. Daniel America - 104.3kg - 230/140/260 - 625kg
2. Nick Rankin - 102.3kg - 200/140/240 - 580kg
3. Will Grainger - 105.8kg - 215/125/230 - 570kg
4. Duke Catherine - 108.2kg - 135/105/190 - 430kg
5. Jeremy Buchanek - 101.1kg - 80/75/75 - 230kg
6. Gregg Gordon - 108.5kg - 80/75/75 - 230kg
125kg class
1. Zoran Jankovski - 114.3kg - 250/145/292.5 - 687.5kg
2. Joe Zollo - 119.1kg - 220/120/240 - 580kg
3. Alan Kissick - 116.8kg - 165/105/215 - 485kg
4. James Thompson - 116.0kg - 110/85/175 - 370kg
140kg class
1. Spiros Markopoulos - 128.0kg - 70/152.5/75 - 297.5kg
SHW
1. Jack Pollard - 148.1kg - 280/170/280 - 730kg
EQUIPPED MEN
100kg class
1. Barry Murray - 97.1kg - 200/160/200 - 560kg
2. Brendan Hains - 95.1kg - 270/BMB/260 - BMB
BENCH ONLY
WOMEN
82.5kg class Equipped
1. Emma Bortolotto - 81.9kg - 90kg
MEN
100kg class
1. Laird Ross - 93.9kg - 180kg
2. Alen Pezerovic - 93.9kg - 130kg
Stoked, got my 102.5kg x3 bench out last night!!!
Week 7 here I come.
Tried doing some paused reps on 90kg and wow that makes it about fifty times harder. No way would I get 102.5kg out without utilizing the stretch-shorten cycle.
the pause does get easier the more you practice it... just have to concentrate on keeping tension
That's what I've found when I've dicked around with the pause. You habitually allow too many muscles to relax when you pause, as your mind wants to use it as a chance to rest....when in reality you want the exact opposite! Keep those muscles tensioned haha
SS as in starting strength?
SS is 3 sets of 5 reps for working sets for sq, bench, OH press
Deads is 1 set of 5 reps
Power cleans are 5 sets of 3 reps.
There are no 5 working sets apart from the power cleans.
and warms ups is a personal thing... if I only did 2 warm up sets and got straight in to the work sets, I'd break more frequently than I do now.
SS as in starting strength by Mehdi
think the program has changed slightly but I could very well be wrong.
Workout A:
Squat
Bench
Barbell Rows (I don't do these, I do seated cable. Reason is I get heaps of pain in my wrist joints from it)
Workout B:
Squat
Overhead Press
Deadlifts
Straight from his book that he sends to everyone:
"You'll do 5 sets of 5 reps (5x5) with the same weight on every exercise after you've done
your warm-up sets. There's 1 exception, Deadlifts, where you'll only do 1 set of 5. Here's
why: 5x5 or even 3x5 Deadlifts would mess with your recovery and cause stalling because
you're already doing 5x5 Squats 3x/week. I urge you to stick with 1x5 Deadlifts."
"Never jump straight into your work weight, warm-up first. As an example, let's say your
work weight for the Squat is 135lbs. Then here's how your training would look like...
• 2×5 45lbs => 2 sets of 5 reps with the empty Olympic bar
• 3 x 90lbs => 1 set of 3 reps with the 45lbs bar + 22.5lbs/side
• 5 x 135lbs => first set of 5 reps with your work weight
• 5 x 135lbs => 2nd set of 5 reps with your work weight
• 5 x 135lbs => 3rd set of 5 reps with your work weight
• 5 x 135lbs => 4th set of 5 reps with your work weight
• 5 x 135lbs => 5th and final set of 5 reps with your work weight"
"Notice that on the Deadlift you only do 1 set of 5 reps, not 5x5 or 3x5 because that could
cause stalling when combined with 5x5 Squatting 3x/week. So let's say your work weight
on the Deadlift is 225lbs, here's then how it would look like:
• 5x 135lbs => 1 set of 5 reps, 1st warm-up set
• 5x 175lbs => 1 set of 5 reps, 2nd warm-up set
• 5x 225lbs => 5 reps with 225lbs, your work set"
No mention of power cleans
If you want to read the entire book that he sends
there it is.
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
