I would have loved a coach when I first started.
Even if just to show me how to do the lifts correctly. For a long time I couldn't squat with an olympic bar because of the pain my lower back received Even now with dead lifts there is a slight bow when i bottom out.
I am going to see Trent at PTC Sydney for this coaching to help get it right.
Also find with a good coach (speaking from other sporting activities) I stay motivated for longer and try harder. Wayne Bennett says he doesnt teach his professional players anything new, he just manages them personally.
food for thought.
Sorry I havent been on for so long, very busy, went to Canberra for the States up there, anyway
Rack pulls. We dont do them as they teach bad habits (hitching). We place the plates on blocks so it mimics the way a bar leaves the floor. We have numerous heights.
Half our lifters pull more off a block, the other half less. Not having momentum at a sticking point makes it much harder. Max has pulled 310kg when he was 75kg, he doesnt get much out of them. Zoran pulls 292.5kg off the floor and 270kg off blocks, clearly he needs the "run up" off the floor.
The best exercise for sticking points I feel is pause deads at your sticking point, stop for a count of 2, then finish the rep.
We love deficit reads, not sure it helps off the floor though as you can use more leg drive on a deficit that isnt there off the floor, but its a great exercise regardless. Do them
5x5 and those clowns claiming it and followers who have no idea why it exists
Bill Starr came up with 5 x 5 when he was asked to write a program for high schools in America to use. Initially he wanted squat/dead/incline but most schools didnt have an incline so he switched to bench press. The 5 x 5 is funny. He said the PE teachers using it were not very smart, and would struggle with a different rep/set scheme, he knew that anyone could remember 5 x 5 lol, so all you guys following it thinking your on something special, think again.
The fact is there is no "best" program, but youre doing one cause its easy to remember and some clown put his name to a program Bill wrote out for dumb PE teachers.
The effort is the key.
To those that claim paused benches are only a benefit for comp lifters, lose the ego, no different to full squats and not hitching your deeds, do the movement properly, your joints will thank you for it when you move to "man" weights
Coaches are important for those that have aspirations, a regular guy at a commercial gym does not need one, he doesnt care that mums can rep his squat PB, nor should he, its clearly not why he lifts, its a social outing, so he can tell his mates he lifts etc.
I hope I havent missed anything. Like I said I was in the ACT over the weekend, awesome comp, some great lifting
I'll post some vids
Big mistake, got injured, ruined his comp. Nathan was planning on 415kg squat, 225kg bench and 330kg dead, a 970kg total to break the All Time 110kg equipped record of 965kg
At the top of the squat he hurt his clavicle and rib, didnt take another attempt, took 2 token benches etc, ended up with 910kg
Jack Hobson benched 180kg at 19yo.....very strong kid
I just realised I have no vids from the Vics up
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
