I would have loved a coach when I first started.
Even if just to show me how to do the lifts correctly. For a long time I couldn't squat with an olympic bar because of the pain my lower back received Even now with dead lifts there is a slight bow when i bottom out.
I am going to see Trent at PTC Sydney for this coaching to help get it right.
Also find with a good coach (speaking from other sporting activities) I stay motivated for longer and try harder. Wayne Bennett says he doesnt teach his professional players anything new, he just manages them personally.
food for thought.
Sorry I havent been on for so long, very busy, went to Canberra for the States up there, anyway
Rack pulls. We dont do them as they teach bad habits (hitching). We place the plates on blocks so it mimics the way a bar leaves the floor. We have numerous heights.
Half our lifters pull more off a block, the other half less. Not having momentum at a sticking point makes it much harder. Max has pulled 310kg when he was 75kg, he doesnt get much out of them. Zoran pulls 292.5kg off the floor and 270kg off blocks, clearly he needs the "run up" off the floor.
The best exercise for sticking points I feel is pause deads at your sticking point, stop for a count of 2, then finish the rep.
We love deficit reads, not sure it helps off the floor though as you can use more leg drive on a deficit that isnt there off the floor, but its a great exercise regardless. Do them
5x5 and those clowns claiming it and followers who have no idea why it exists
Bill Starr came up with 5 x 5 when he was asked to write a program for high schools in America to use. Initially he wanted squat/dead/incline but most schools didnt have an incline so he switched to bench press. The 5 x 5 is funny. He said the PE teachers using it were not very smart, and would struggle with a different rep/set scheme, he knew that anyone could remember 5 x 5 lol, so all you guys following it thinking your on something special, think again.
The fact is there is no "best" program, but youre doing one cause its easy to remember and some clown put his name to a program Bill wrote out for dumb PE teachers.
The effort is the key.
To those that claim paused benches are only a benefit for comp lifters, lose the ego, no different to full squats and not hitching your deeds, do the movement properly, your joints will thank you for it when you move to "man" weights
Coaches are important for those that have aspirations, a regular guy at a commercial gym does not need one, he doesnt care that mums can rep his squat PB, nor should he, its clearly not why he lifts, its a social outing, so he can tell his mates he lifts etc.
I hope I havent missed anything. Like I said I was in the ACT over the weekend, awesome comp, some great lifting
I'll post some vids
Big mistake, got injured, ruined his comp. Nathan was planning on 415kg squat, 225kg bench and 330kg dead, a 970kg total to break the All Time 110kg equipped record of 965kg
At the top of the squat he hurt his clavicle and rib, didnt take another attempt, took 2 token benches etc, ended up with 910kg
Jack Hobson benched 180kg at 19yo.....very strong kid
I just realised I have no vids from the Vics up
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
