The most I got to on SLDL was 120x10 before switching to off the ground. They were certainly tough, particularly on grip because you can't rep reset like off the ground. Great for people with limited flexibility too.
Do you guys do any grip specific training or just let the compound pulls do their work over time? Is there such an exercise as just standing there in a lockout until your grip starts to give way?
Didn't do the week 11 of the PPP 180kg deadlift but did the following;
60 x 5
100 x 5
140 x 5
150 x 3
160 x 3
170 x 1
180 x 1
Got my 180kg PB! It was nice seeing 4 x 20kg plates each side lol. Am absolutely wrapped with that.
Weighed in today at 78.9kg so lightest I have been in 15 years yet have lifted more than I ever have.
60 x 5
100 x 5
140 x 5
150 x 3
160 x 3
170 x 1
180 x 1
it's a good reward when you see the numbers go up
60 x 5
100 x 5
140 x 5
150 x 3
160 x 3
170 x 1
180 x 1
Grats dude! :)
192.5/100/210 - 502.5 at 87.9kg
2.5kg PB / 10kg worse than PB / 10kg worse than PB.
5kg lighter bodyweight.
Happpy with the sq PB.
The others are still weak but it's as good as I could get them since last injuries.
Hoping to improve SQ and deads by June.
Bench will prob stay the same cause I won't be training it much if at all.
Once again, I hate wraps.
so so much pain.
Edited by TTT
    • Definitely a good “future upgrade” option if you plan on keeping the car and dialing it in even further.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
