I started this thread because there was so much stuff being posted that I didnt agree with in other threads, but I realize that not everyone wants to be strong
This thread is for those that do
So my posts in my powerlifting thread will always be about increasing your 1RM
Looks like I'm going to be getting lots of bench practice for the next week or two
did something to my lower back... right down the bottom, near my upper glutes... can't bend over at all... sitting and standing are very painful... lying down is okay... getting dressed is a challenge... might just go to bed clothed, will make things easier tomorrow lol
I've strained my erectors before but this is different... lower down and much more painful
I'm lifting at Nats... even if I have to do so in a wheelchair... so my back can kiss my arse
there's two vaginas... a front one and a back one;)
yep will be seeing Jason Mawby as soon as i get the correct phone number lol
leg movements are okay... walking not too bad... hurts to twist
anything remotely like a deadlift movement hurts the worst... TBH I'm pretty sure I did it last week... thought it was just tightness/soreness so I did a long warm up and lots of rolling... felt sore but I went for my working set anyway... it didn't pop or anything just knew as soon as I'd finished the set I was in trouble
just hit it with the hot water bottle and it's a bit better... which leads me to think it's just a strain... hopefully I can just skip squats/deads this week and it comes good
Wayne slipped on a roof and cut his leg very badly... Liam has a knee issue that he had surgery for... surgery didn't work but then they found another issue that needs time to heal
I think I hurt my back as a direct result of giving Wayne crap about having to load his plates for him... karma is a bitch
I'm off to see Jason tomorrow morning, then drop in at PTC for a bench session after... hopefully it's just an alignment issue, maybe a pinched nerve that can be fixed with some manipulation
That time of the year again. A few of my guys are riding that fine red line atm as they prep the final stages for nats.
Seeing emads snap has shocked a few of the guys into spending more time on
Mobility - rehab and prehab is up more than normal.
Edited by trentzor
Saw Jason this morning, have to go back on Thu after I get my X rays
he told me to stand in front of the mirror and showed me how crooked I am... it was ridiculous and weird that I've never noticed it before
he did say it's possible I have bulging or slipped disk but I think I'd be in much more pain... definitely no nerve damage which is good... lots of ice for the next 48hrs
hopefully the ice will reduce the inflammation, the x rays will be clear and some manipulation will have me back lifting in a week or two
he did say once he gets me straightened out I should see a strength increase
on a brighter note I benched 125kg x 3 for 3 sets... still on track for my first 3 plate bench press
lol......no amount of prehab would save anyone from what happened to Emad
The operation is tonight, they are doing a biopsy on his bone to find the cause of the snap, as in disease, it has nothing to do with lifting weights, your humerus doesnt snap benching 110kg. It doesnt snap benching 400kg. It snaps if there is an issue with the bone.
I know mate lol. I should have clarified.
His was a freak accident.
Nothing could have prevented it.
It's pretty rare though I haven't seen such a break before.
Any specialist ideas on what caused it?
Plenty of guys bench for years without snapping it as such.
Keep us updated on how his going after op.
Edited by trentzor
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
