Poor fella must be devastated, hes lucky he didnt get hurt more from the bar falling on him.
He must have some sort of underlying bone issue. Especially when you consider that he lifts 4 times or more a week and should have really good bone density due to the stress of lifting stimulating appositional bone growth an remodeling.
Edited by Mitcho_7
sooo I have suspected disk prolapse between L4 and L5... spine is a long way out, I lean to my left which is probably what has caused it... my lumbar is also very compressed, along with some other more minor issues in my mid back and neck
I have 4 weeks of treatments twice a week... Chiro pretty confident he can fix me up in that time and reckons I'll come back much stronger... thinks I've been leaving a lot of strength on the table being as misaligned as I am... I didn't ask if I'll make Nats, I guess we'll wait and see
Happy to train through knee, shoulder, elbow pain etc but don't want to stuff around with my back... will be doing what he says (he's a fellow powerlifter)
have the all clear to keep benching/pressing... just no overhead work
Jason Mawby
http://www.mawbychiropractic.com.au/
He won't adjust you without a full spinal xray... They are in Rosebud and will refer you to an xray place down there but I'm sure you could get them done anywhere
Went and saw him first but I guess you could have some xrays done first
Did he say if the heavy lifting might have contributed to it?
Did he tell you to stop the heavy lifting or go easy for a while?
I hurt it while deadlifting, no doubt about it... only because I was lifting whilst badly out of alignment... I'm sure I would not have had any issues had I been seeing someone to have maintenance work done instead of waiting til I hurt myself
I pulled 200kg x 5 for 3 sets... then deficit deadlifted 180kg x 8 and 160kg x 13 (to failure)... I'm pretty sure I did it in that last set... I was fatigued and let my form go, plus I was lifting from a deficit and it's already hard for me to get down to the bar and setup correctly... I was then very stiff in that area for the next week but kept lifting anyway... on my next DL session I warmed up a lot because of the stiffness but everything felt heavy... my top sets were supposed to be 215kg x 3 x 3... I pulled the first set and only barely managed it... felt like I strained something and immediately it started to hurt
he said no deads or squats for the time being... no overhead lifting or anything that compresses my spine... I'll get the treatment and as soon as he clears me I'll get back to it... I'm already seeing improved movement every day and I've always healed quickly so fingers crossed
Yeah hope it gets sorted soon.
I guess the qn to ask is are you still keen on lifting big weights now this has happened to you?
After I hurt myself, and nowhere near anything like you did, I qn whether there is any need to lift heavy. You compete but I don't.
I probably shouldn't have these thoughts in this thread................. Lol
it sounds a lot worse than it is... I'm really not in that much pain, just uncomfortable bending over and sitting for long periods
I can't wait to lift heavy again... I don't feel right not having squatted for nearly two weeks lol
However I won't be lifting heavy unless everything feels right in that area and I get the all clear from the Chiro... I won't ignore it again
I had this week off except for a short bench session but I'll be back into 4-5 sessions a week next week... lot's of bench pressing, supported rows, pull ups, dips etc
TTT: thanks mate... I'll be pretty gutted if I miss Nats... never thought I'd ever do a bench only comp lol! But if I'm not healthy then I'll live to lift another day... I'm sure there will be some other comp I can do later in the year
will be a pity because I hadn't missed a rep in training and was programmed for a 610kg total... think I could nudge 620kg fully healthy too
shit happens, people have come back stronger from a lot worse injuries
Jason Mawby looks after our entire team, he has totalled 600kg@100kg, his wife also competes.
He fixed up Nina and Max, they still get alignments every fortnight, I think he has around 30 clients from PTC
Emad is out of hospital. What was supposed to be a 1hr op lasted 3. His bones are like concrete, they struggled to drill through them
Dr Bruce Reid and Dr Peter Larkins believe there was a stress fracture there that the MRI didnt pick up
He has a titanium rod running through his humerus now. He was in the gym today.
Nick, you'll be fine if you listen to Jason, we work together, we have a 100% success rate. Max started squatting an empty bar after Jason realigned him, he is about to squat 250kg x 4.
You wont recognise the place when you walk in lol
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
