Hi mate, 9.5 CR is fine just can't run big boost, it's mostly in the tune anyway, if you have a united servo down there they will have premium 100 soon if not already, the servo around the corner from me said they are all getting it weather that's true or not is a different story, and maybe even E85
https://www.sau.com.au/forums/topic/407505-rb2530-cr-on-98/#findComment-6497288
30psi with 9.3 CR, got a link I would be interested to see that one and what mods he has done, I know there is a guy on here with a built 2.6 engine with 9.3 running a little over 20 psi on 98, but then your dymanic comp ratio would change the amount of boost your can run also, with big cams creating lots of overlap and reducing the effective stroke will reduce the DCR
so you might have 9.3 static comp ratio but then have big overlap and reduce the DCR to ( and this is just a guess for discussion sake ) 7.5-1
https://www.sau.com.au/forums/topic/407505-rb2530-cr-on-98/#findComment-6497446
here is link http://www.skylinesaustralia.com/forums/topic/395232-394kw-1994-r33-gtst-act/ he said he has run up to 30 psi
yes i dynamic CR is less with big cams ( every cam changes it)
was thinking of running camtech 268 dur ,9mm lift in (with VCT) and 272dur 10.4mm lift
and yes for my HD
https://www.sau.com.au/forums/topic/407505-rb2530-cr-on-98/#findComment-6497498
Depends on so many different factors. It's easy to say "He did this with this turbo, pistons etc." and it was OK...doesn't mean YOUR build will be EXACTLY the same and also be fine.
E.g. My RB25/30DET, Static 9:1 CR (there abouts), 256/8.5mm Tomei Cams, 18PSI @3500-4000RPM. Pretty much copied Cubes' RB30 build. However, the thing wanted to ping its head off on BP98. More so than normal and definately not like Cubes' RB30.
Chased our tails (tuner and I) for a little while...Eventually, chucked some more fuel into it, pulled some timing and it was all good. Sacrificed a small amount of power for some reliability. However, the thing is definately more sensitive to knocking than the run of the mill RB.
If it were me, I'd be going E85 just for the sake of it.
Is it going to be a build for a road or track car?
https://www.sau.com.au/forums/topic/407505-rb2530-cr-on-98/#findComment-6498511
Hmmm from an initial glance, there isnt that many servos (is there any???) that run E85 around your area anyway! Could always buy it by the barrel since the car isn't going to be a "daily" driver.
Worst case scenario, tune for 98 and see what you can get away with. If you're having issues with the thing knocking and you're not happy with the power/torque, chuck the juice at it!
If it were me, depending on your turbo choice, I'd be keeping it to 9:1 on 98...
Edited by R32Abuser
https://www.sau.com.au/forums/topic/407505-rb2530-cr-on-98/#findComment-6498707
smaller turbo more cr ?
https://www.sau.com.au/forums/topic/407505-rb2530-cr-on-98/#findComment-6501840
Im not sure what you're trying to ask in the above post...
As a very general statement: The smaller turbo you run, the higher the EGT's will be and thus increase the sensitivity of the setup to knocking (apples with apples of course!). Run a higher Static/dynamic CR and you will only make the problem worse.
Edited by R32Abuser
https://www.sau.com.au/forums/topic/407505-rb2530-cr-on-98/#findComment-6508065
I mean when the turbo size gets bigger the cr should digress?
https://www.sau.com.au/forums/topic/407505-rb2530-cr-on-98/#findComment-6514627
Now I'm confused...
The turbo you use won't change your comp ratio. Comp ratio is a mechanical thing only modified by structural changes to head shape, piston shape, deck height, etc.
If what you're asking is "When you put on a bigger turbo will it cause comp ratio issues (pinging)" then yes, correct. The higher the static comp ratio, generally the less boost you can pump in without detonation issues. Unless of course you up the type of juice you're using to overcome these issues (100+ octane or E85 which is a more stable fuel under high compression). Sometimes the shape of the piston and combustion chamber can affect this too. Sharp edges that get super hot can cause pre combustion too.
Is that what you're getting at?
https://www.sau.com.au/forums/topic/407505-rb2530-cr-on-98/#findComment-6515308
Maybe get back to why you want to run so much static CR? On a 25/30 a few points more CR isn't noticeable... I've had a 25/30 around 8.4:1 and it was noticeably torque-ier than the 25 bottom end it replaced. New pistons took the same motor up to 9.4:1 and there was very little.... if any difference.
Generally, a smaller turbo will make more heat, require more boost and create more back pressure/egt for the same hp...
At the end of the day, what would you like from your car? how much hp will get you there? what turbo is best matched to your engine for the power goal?
The turbo selection will make the biggest difference difference to your power delivery and potential. The old school NA v8 3C's (cams/compression/carbies) have a much smaller affect on power delivery/potential of RB's than you might think.
Cheers
Justin
https://www.sau.com.au/forums/topic/407505-rb2530-cr-on-98/#findComment-6518250
Cheers
Justin
to get it to have better off boost RESPONCE
https://www.sau.com.au/forums/topic/407505-rb2530-cr-on-98/#findComment-6518470
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
