Hey,
Just wondering if anyone here is interested in a group buy for front bumpers, side skirts etc.
The bumpers are from BAUSauto from g35driver, I was quoted $675 shipping just for the Fiberglass 03-04 Sedan KuRookie Front Bumper.
If anyone is interested, pricing and photos can be found on this thread below, this thread is only for the sedans, will be getting more information about the coupe from them.
http://g35driver.com...-place-get.html
Edited by itsRICHARD
They still sell bumpers they're also called http://carbodykits.com/ if you google BAUSauto you can find their facebook page. They're the only authorized dealer for the KuRookie bumpers atm.
For the coupes I don't think there's a thread but you can search Infiniti G35 and your year make on http://carbodykits.com/
Okay, so I really wanna get this front bumper. I was told each box can fit 2 bumpers and some small accessories in them, I'm thinking of getting the KuRookie Front Bumper and maybe the NisRookie Side Skirts, if you are interested, now's the time to tell me which bumper you're after and the year and make of your car so I can put down a list and get a quote.
If you're from Melbourne you can pick it up from me and save money from shipping :D
Also, they told me they have just about every body kit from every brand including their own line, so let me know which you're after and if you want poly or fiberglass (some only come in fiberglass like the KuRookie sadly)
Hi Richard, good initiative, Ive been meaning to get onto this. I'll be at the V meet Friday in any case.
Can you ask them if they have Poly versions of any of the below for a coupe pls? They are just front bars, but I would happily look at a full kit
- Chargespeed
- Kuruma Z
- Inven
Strafe or Klumyzee Version (with or without the CF Splitter)
- Chargespeed
- Kuruma Z
- Inven
Hey Andrew, which year model is your v35?
See you on Friday at the meet :)
Hi Richard, mine is a 2003 coupe.
Thanks again
Hey Andrew,
Just received a reply,
they have the
$350 Poly Urethane Kuruma Z Front Bumper
$350 Poly Urethane Inven Front Bumper
But not the Chargespeed in Poly.
Started a new thread to get the actual group buy started :)
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
