I am very curious on peoples opinions on what they consider is fast. my car was put on the dyno last week and was making 222kw at the wheels at 10psi boost. I have standard injectors so I cant go higher than that.
problem is though, the car feels laggy as hell, and seems slower compared to the standard turbo I had previously on it. I am just not impressed. why? :(
anyone happy with 220kw at wheels?
https://www.sau.com.au/forums/topic/407706-is-220kw-at-the-wheels-powerful/
Specs and dyno sheet needed!
Ill get on that soon man. but whats your opinion? shouldn't 220kw at the wheels be brutal?
because my car aint brutal unless I boost from 1st gear. anything higher than that takes forever for the damn turbo to kick in. hits hard when it does though, but damn it takes forever. not happy with the performance of the r33 gtst :(
220kw is nothing to get excited about BUT you did say it was at 10psi which is probably not even waking your turbo up, hence your not happy! If you have a bigger turbo thats what happens!
what turbo do you have?
when are you hitting boost by?
is anyone happy with 220 atw? maybe.. its personal preference. get some bigger injectors/pumps/reg and wind the bitch up
high flow garret turbo. hitting boost pretty late man...
edit: ok my tuner just called, he said he wasn't looking to get power out of the turbo until I had run in my new engine. he said it was a conservetive tune, Ill be taking it back to him on monday for him to improve the timing on the ecu or something. apparently thats why its not accelerating hard... :unsure:
Edited by BOOSTBIG
power coming on too late means slow car, eg dyno queen.
If you did fuel injectors, airflowmeter, you could then use more boost and wake it up...
Otherwise maybe the turbo is too big?
I drove an R33 GTS-t years ago and it had high flowed turbo, front mount, injectors, tune, exhaust running 18psi, it was bloody good!!! Felt like 250-270RWKW
Yea man, with the amount of mods done to my car you would think it would be pulling hard!
lets see what happens monday. if not ill be selling it and buying a gtr lol
anyone want a fully rebuilt r33 gtst? lol
On the flipside of that Sean i had a high flow on my car making 250kw and it was pretty disappointing, so some good and some bad i guess.
True. The one I drove was right on the limit, as it was knocking on high boost! We are talking like over 8 years ago haha..
A laggy turbo that has a useful powerband of say, 5500RPM through to 7000RPM will feel fast (ramps up onto boost quickly) but will actually be slow compared to a car with a more useful powerband.
Big difference between "feeling fast" and actually "being fast" and it's all in the powerband.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
