Hey guys my car is running rich so im taking steps to try to stop this, I am looking for a O2 sensor and im not sure what i should go for there are many online starting from $70 and then i read somewhere that im better off getting a wideband o2 sensor with a guage so i can view it myself also to know the A/F ratio, i may plan to put a power fc in my car R33 so I cant decide weather i should put in a wideband with Guage (AEM) link below, NTK or NGK, Bosche or Australian Fuel Injection.
Kind of confused
this is the wideband aem one im looking at
http://www.ebay.com.au/itm/AEM-30-4100-DIGITAL-WIDEBAND-UEGO-CONTROLLER-AIR-FUEL-RATIO-FULL-WARRANTY-/330682646907?_trksid=p4340.m8&_trkparms=algo%3DMW%26its%3DC%252BS%26itu%3DUCC%26otn%3D12%26ps%3D63%26clkid%3D1564762916054738581#shId
your car has a factory narrowband sensor
the stock ecu and PFC (and most ecu's) assume you have a stock narrow band sensor
you cant just remove it and install a wideband sensor and expect it to work
if you do install a wideband sensor as a narrow band replacement then you need to ensure the controller for the wideband sensor has narrowband output
this is usually a 0v to 1v output which the stock ECu will use and trick the stock ecu into thinking you have a narrowband 02 sensor
narrow is 0v to 1v
wide is 0v to 5v
a/f guages are useless on narrowband sensors and only meaningful on wideband sensors
stock ecu assumes (and pfc) narrowband and will only work on narrowband sensor (or fake narrowband input from wideband controller)
narrow band 02 ssensor should be $80
wideband 02 sensor form memory around $200
the stock narrowband sensor does die and it only has limited service life
from memory approx 100,000kms or so so yes, its a good idea to replace it
and you may yield some fuel economy as its the sole sensor responsible for fuel economy management
with a f**ked 02 narrow band sensor the stock ecu cant trim the fuel map on its own and its probably wasting fuel
note - dont confuse this with black smoke when you flog it on boost
when you flog it or floor it the stock 02 sensor is ignored and the ecu does all the work
the stock narrowband sensor is only used on light cruise / light throttle
when you open the throttle / floor it / on boost the ecu goes into "closed loop" and ignores the 02 sensor
from that auction page it wont work on the stock ecu (or PFC) because
All AEM digital gauges feature a 0-5v analog output for use with data loggers and virtually any engine management system, such as the AEM EMS or FIC.
the stock ecu and PFC only run 0v to 1v analog input
so you need an wideband 02 sensor / controller with analogue output
Get the Innovate LC-1 with DB Gauge, can be had from eBay US to your doorstep for under $180.
Supports BOTH wide & narrowband.
Disconnect your stock O2, splice in the narrowband channel to your ECU. Save the wideband channel when you start stuffing about with tuning.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
