still having some issue with my 96 gtst r33 skyline.
Basicaly i have a Blitz 3" full exhaust with big down pipe and decent size Fmic, the exhaust came with a bolt in restrictor,silencer for the end of the exhaust as a option to run.
With the restricter in my car gets to a solid 9-10psi and is basically a missile(never hitting boost cut).
However i like the loud of the system without this restictor/silencer installed on the end, but my car then boost to 10-12psi then just hits boost cut? which is why its annoying me.
The question is , does this sound normal ?and is it normal for big exhaust to make more boost?.
would a r32 7psi actuator be the answer?.
I dont really want big boost yet as im saving for a power fc.
I have fuel cut defender but dont know how to adjust it/install.
Im thinking of trying a 2.5" restrictor plate in exhaust, this silencer is ugly hehe.
Is there ways to keep/get boost low?
https://www.sau.com.au/forums/topic/407956-bigger-exhaust-more-boost/
An r32 actuator is a 10psi spring, your's should be a 5psi spring unless its been changed in the past. Are you running the stock boost solenoid? when I dropped my exhaust from before the cat I saw no more than 9psi.
A boost controller can lower the boost for me also?
actuator is directly hooked up with 6mm short hose to fmic pipe for least boost possible?
It may have a r32 10psi actuator already? as it seems to hit 10psi but then creep to 12 at he end.
with the restrictor in it boosts as you want and is quieter, win win?
Yeah its not bad quiet but would like it louder without the restrictor.
What are the good cheap option ecu's? would like a power fc but how do the cheaper piggy back ecu's perform?
maybe your stock turbo's wastgate has reached its limits , it might not be able to vent off any more at the top end so its spiking..
if this is true then your on the edge of needing a hiflow/turbo upgrade
as a cheap alternative you could take the turbo off, remove the exhaust housing , take it to turbo shop and tell them to hone out the wastegate area and fit a larger flapper.. ( XR6 turbo flapper was used on my old turbo)
then your boost should be whatever the spring is..
Edited by SliverS2
it's hard to do good & cheap with ecus, nistune prob most eco, link g4 is good ,does boost control & doesn't need z32 afm so in the long run not too bad if you're going to go further, there's a few reputable tuners on here so see who's in your area and they'll be able to recommend for your goals
i did think this with boost creep but how common is this senario?
I mean my car is std except pod,bigger fmic and big exhaust.
I think i need to make sure its a 5psi actuator?as it may have a 10psi one.
about the std r33 dont they get to 7psi? not 5psi
thanks
what of wolf ecu? or greddy ecu?
Im seeing them cheap atm.
I did think nistune but is it just plug and play?like swappng a pc graphics card? basic tune on it? diy it? until i can save for tunes
sorry still a noob with skylines obviously hehe
If you had an R32 actuator on it you would always have had at least 10 psi boost. Seeing as you used to have 9-10, then it IS possible that your actuator is not a 5psi one.
My suggestion. Put the silencer in, and don't worry about having a louder exhaust until you can afford the management issue. Noise is just fashion, and fashion is for wankers. The only thing that is really important is how well shit works.
5psi till 4500 rpm then 7psi. If you ground one of the cables then you can mod it to run 7psi constant =)
He just said before that he has a straight vacuum hose from the pressure source to the wastegate actuator. So he doesnt have any wires to ground. Also, he wants to lower the boost, not increase it.
The stock wastegate should be fine with those mods, and a little gate creep is normal. You don't need a bigger wastegate flap, a new ECU or a high flowed turbo. And you shouldn't need to run a stupid f**king restrictor in the exhaust. Your just painting over dirt.
I'm willing to bet it has a bigger actuator fitted, just go and fit the original actuator back onto it and your problems will be solved.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
