Baby Zilla Posted February 27, 2003 Share Posted February 27, 2003 Guys, In case anyone is interested, after driving around to all the ****wit Nissan dealers in the state, I eventually took my car to Blackburn Nissan. They were great! Fixed the problem in less than a day and very reasonable on price. The problem turned out to be the connection for the Air Flow Meter. Boost on... Link to comment https://www.sau.com.au/forums/topic/408-this-low-rpm-engine-stalling-saga-possibly-sorted/page/4/#findComment-186975 Share on other sites More sharing options...
skylark Posted March 5, 2003 Share Posted March 5, 2003 Originally posted by BOOSTMEISTER Find the earth wire from the pump and cut it and run it directly to a good ground on some bare metal in the boot area......fixed. I have an R32, the fuel pump entry point on R/H side of spare when standing at rear of vehicle? Plug connection under metal shield with arrow on top joins fuel pump wires to rest of harness? Wires=blue w/red trace, white w/purple trace, yellow w/green trace, yellow and also black. I am assuming that black is the earth? Can I just cut it before the plug then? Apologies for my ignorace but it is better to be safe than sorry and I would really like to fix my idle issue. Link to comment https://www.sau.com.au/forums/topic/408-this-low-rpm-engine-stalling-saga-possibly-sorted/page/4/#findComment-198163 Share on other sites More sharing options...
skylark Posted March 6, 2003 Share Posted March 6, 2003 :( :D Well, I had to take my balls in my hands and do it myself. After I regained the strength in my arms I got to work. Cut the black wire and earthed it out under one of the screws holding down the metal plate with the arrow on top. Started car and idle was still a little up and down after I gassing car while it was in neutral. Took it for a real thrashing on a private road, a REAL thrashing, then drove it around off boost for 10-15mins and came home. Purrs like a kitten, idle steady. Now I'm going out to give the AAC valve a carby cleaner shower and wave goodbye to this embarrasing problem hopefully forever.! Link to comment https://www.sau.com.au/forums/topic/408-this-low-rpm-engine-stalling-saga-possibly-sorted/page/4/#findComment-201399 Share on other sites More sharing options...
KAOS Posted March 8, 2003 Share Posted March 8, 2003 STALLING AT LIGHTS ETC. ESPECIALLY WHEN A/C IS ON I don't think anyone has touched on the possibility of a vacuum leak. It is highly possible this is why the cars are stalling at the lights etc. We work with a lot of skylines and this is often the problem. A leaking BOV etc. will do it but more commonly it will be perished vacuum lines. Just behind the throttle body is a problem area. Just listen for the hiss. See how you go. Link to comment https://www.sau.com.au/forums/topic/408-this-low-rpm-engine-stalling-saga-possibly-sorted/page/4/#findComment-205601 Share on other sites More sharing options...
KAOS Posted March 8, 2003 Share Posted March 8, 2003 Sorry to post again so soon, but just a couple of things. In cars that I have dealt with, If it idles up and down try Air Flow Meter or Oxygen sensor. We've had this problem a bit...mostly AFM.....might not be such a good idea to take the mesh out after all. If it surges when you tromp it but will rev smooth if you ease it....definitely Fuel Pump. Seriously guys, if you own a turbo skyline get a new pump asap. We've dealt with a lot of them and the stock pumps always die. When the cars are imported they have very little or no fuel in them and I think this has something to do with why they fail. It is so common a problem I think it should be part of compliance. It would sure avoid a lot of unnecessary engine rebuilds. Leaning out due to a weak pump is real bad news. We sell them but get one from anywhere. Go the Bosch 044 good for 650hp Hope this helps. Link to comment https://www.sau.com.au/forums/topic/408-this-low-rpm-engine-stalling-saga-possibly-sorted/page/4/#findComment-205612 Share on other sites More sharing options...
Endorean Posted March 9, 2003 Share Posted March 9, 2003 What's the Fuel Enconmy like with the Bosch 044, or does it not really matter with the Fuel Pump, it just's maintains the pressure. What's the price of the pump as well. 2 things that I have noticed with my R33, first, at idle the Vacumn gauge sits just below 0, would that indicate a vacumn leak? What's the easiest way to confirm that there is a leak. Second, I took the drivers side kick panel off to check out the ECU, and what was staring at me. 2 exposed wires that were covered by electrical tape. Should I repair these connections so it isn't exposed. (stupid question I know, just wanted to get the reassurance from those more experienced then me). Link to comment https://www.sau.com.au/forums/topic/408-this-low-rpm-engine-stalling-saga-possibly-sorted/page/4/#findComment-206494 Share on other sites More sharing options...
R31Nismoid Posted March 11, 2003 Share Posted March 11, 2003 yep. repair the wires... as in solder them really well. Had a similar problem with a 31 coupe i had... Caused it to trip out all the time with different error codes Link to comment https://www.sau.com.au/forums/topic/408-this-low-rpm-engine-stalling-saga-possibly-sorted/page/4/#findComment-209714 Share on other sites More sharing options...
boosted32 Posted April 1, 2003 Share Posted April 1, 2003 I thought I'd post a reply with my recent experience with this stalling problem... When my car was allowed to idle it would idle fine for about 10 seconds then the pump would stop completely (no sound from pump at all), then about 4 seconds later the engine would cut out (no fuel of course). As mentioned in this thread, the pump control module normally goes into low speed pump mode by switching in some kind of resistor on the earth of the pump. We wired the pump earth straight to ground and the problem was completely solved. We aren't completely sure of the cause, but there seem to be 2 possibilities: 1) I have an after-market pump and with a resisted earth it doesn't have enough power to run. 2) The resistor circuitry in the pump control module is buggered and not working. We are considering swapping out the pump control module (located behind the panel on the right hand side of the boot) for a known working module out of another car. An interesting result of the stalling problem is that we couldn't get the car to idle at less that about 1100rpm. This would seem to make sense as the pump control module has a RPM feed and may only kick in at less than about 1100rpm. With a proper earth the car idles stable at 750rpm even though we haven't been able to tune it at that RPM yet. Link to comment https://www.sau.com.au/forums/topic/408-this-low-rpm-engine-stalling-saga-possibly-sorted/page/4/#findComment-251885 Share on other sites More sharing options...
maximumrpm Posted April 16, 2003 Share Posted April 16, 2003 i had the same problem...it was the BOV not connect properly...it should fix the prob...it did for me...and when it did stall it did it in 2nd gear at low revs Link to comment https://www.sau.com.au/forums/topic/408-this-low-rpm-engine-stalling-saga-possibly-sorted/page/4/#findComment-283064 Share on other sites More sharing options...
Guest VuDuDoc Posted April 22, 2003 Share Posted April 22, 2003 Now i have a here there type problem. it seems that the power is here and there. rough start in the AM and after that kinda alright.....as rpms increase slowly there is a sudden burst on the powerband. i have a HP pump @255lph/55psi.....wierd Link to comment https://www.sau.com.au/forums/topic/408-this-low-rpm-engine-stalling-saga-possibly-sorted/page/4/#findComment-292559 Share on other sites More sharing options...
R31Nismoid Posted April 22, 2003 Share Posted April 22, 2003 i actually went to mod my fuel pump the other day and found it's directly connected to the ignition so it's on constantly, and mine still does this stalling. I'm getting a bigger pump in a few weeks so i might re-wire again and see what happens. Link to comment https://www.sau.com.au/forums/topic/408-this-low-rpm-engine-stalling-saga-possibly-sorted/page/4/#findComment-292606 Share on other sites More sharing options...
maximumrpm Posted April 24, 2003 Share Posted April 24, 2003 mine use to stall with a aftermarket BOV..i just added a T-piece contector and added the 2 out take lines off the BOVS (factory + blitz) together and back to the throddle body and havent had a prob since...i also noticed that the car ran alot smoother as well. Link to comment https://www.sau.com.au/forums/topic/408-this-low-rpm-engine-stalling-saga-possibly-sorted/page/4/#findComment-294774 Share on other sites More sharing options...
R31Nismoid Posted April 24, 2003 Share Posted April 24, 2003 i don't have a BOV on mine. *wonders if it's that?* Link to comment https://www.sau.com.au/forums/topic/408-this-low-rpm-engine-stalling-saga-possibly-sorted/page/4/#findComment-294783 Share on other sites More sharing options...
Guest Shnea Posted May 9, 2003 Share Posted May 9, 2003 mine is doing that same problem, i am yet to try the fuel pump trick. just wondering if the 180sx you did it on had a BOV that vented to atmo. Thanks Link to comment https://www.sau.com.au/forums/topic/408-this-low-rpm-engine-stalling-saga-possibly-sorted/page/4/#findComment-319251 Share on other sites More sharing options...
Guest Shnea Posted May 9, 2003 Share Posted May 9, 2003 And do you think it could have something todo with the lower octain levels in AUS compared to japan? Link to comment https://www.sau.com.au/forums/topic/408-this-low-rpm-engine-stalling-saga-possibly-sorted/page/4/#findComment-319297 Share on other sites More sharing options...
Guest VuDuDoc Posted May 9, 2003 Share Posted May 9, 2003 fuel pressure regulator over fueling could be the problem...... Link to comment https://www.sau.com.au/forums/topic/408-this-low-rpm-engine-stalling-saga-possibly-sorted/page/4/#findComment-320240 Share on other sites More sharing options...
Nizmo32_Josh Posted June 4, 2003 Share Posted June 4, 2003 i have an r32 and found that earthin the black wire did not keep the fuel pump on but killed my fuel gauge. after hunting for the relay that switches off the fuel pump (near boot latch under trim) i cut and joined two wires (after testing first!) and now the fuel pump stays on with ing. did it last night and am at work now so no real test time yet. Link to comment https://www.sau.com.au/forums/topic/408-this-low-rpm-engine-stalling-saga-possibly-sorted/page/4/#findComment-360978 Share on other sites More sharing options...
sven laptop Posted June 11, 2003 Share Posted June 11, 2003 The guys at UPI just raised my idle speed a little (from 600 to about 850rpm) & it hasn't stalled since! Link to comment https://www.sau.com.au/forums/topic/408-this-low-rpm-engine-stalling-saga-possibly-sorted/page/4/#findComment-374639 Share on other sites More sharing options...
Guest Shnea Posted June 11, 2003 Share Posted June 11, 2003 I took mine in and it was a valcume leak, they never plugged up where there was a boost gauge Link to comment https://www.sau.com.au/forums/topic/408-this-low-rpm-engine-stalling-saga-possibly-sorted/page/4/#findComment-374661 Share on other sites More sharing options...
Nizmo32_Josh Posted June 11, 2003 Share Posted June 11, 2003 car now goes great with no problems at all. also noted that idle quality changes with timing. sorry if someone has metioned this previously. Link to comment https://www.sau.com.au/forums/topic/408-this-low-rpm-engine-stalling-saga-possibly-sorted/page/4/#findComment-374713 Share on other sites More sharing options...
