hey guys i have a s2 rs4s and its knocking/rattling. ive checked it with a stethascope, and the noise is coming from the rear of the engine or bellhousing. i believe these have a dual mass flywheel and this is where the noise is coming from but looking for some clarification from anyone whos pulled a fly wheel out of one.
cheers.
Never seen a dual mass flywheel on an RB but then I haven't seen that many RB flywheels. I would think it very unlikely. On the other hand it is quite possible that someone has fitted a twin plate clutch if your engine has been heavily modified (they are not standard).
Or else you have a screw loose somewhere?!!
this is an oem replacement for a dual mass flywheel on an R34 GT-R
OEM equivalent clutch kit including DMF NSK-7725DMF
this is also for sale on SAU
from an R34 GT-R VSpec
Stock used
Used dual-mass flywheel now for sale - Will inspect condition and update. For now price = $250, may go up or down $50 depending on confirmed condition (will post pics)
so skylines definalty have them and i thought, being a NEO engine, with gtr gearbox(if that waht the awd box is), it may have the GTR dual mass flywheel. im not sure if the GTT had them, but its possible aswell.
Edited by OMY31T
Well I remain unconvinced. From my "research" the only Skyline to have a dual mass flywheel as OEM is the R34GTR with the 6 speed Getrag although aftermarket dmfs are around.
I have an R33GTR box and clutch in my Stagea and the clutch and flywheel came out of a low mileage R33GTR and its a solid flywheel. I'll bet quids that the RS4s came out with a solid flywheel.
mmmm i guess ill just have to pull it out, because its really the only explaination for the noise that i can come up with.... it doesnt sound like piston slap, and all of the cylinder compression are good, i thought it may have been the idler or tensioner pulley for the timing belt, but they have been checked and are fine. the car drives beautifully so its unlikely to be an internal bearing.....
this has really got me by the short and curlys, its all thats stopping me from sending the turbo off to hypergear, got the FMIC, fuel pump, z32afm, hard pipe intake, all i need is the turbo and ecu + tune, but im not going to send it off and power it up if its going to cause more problems...
As stated before, 6 speeds get dual mass flywheels a la 34gtr and s15
Quite likely to have copped a twin plate clutch in japland, extra likely if your clutch is quite firm
Disconnect either injectors or spark down the back end of the motor (one at a time) and check if the noise goes.
If it does it will more than likely be big end bearings, Happened to me on my R33 a few years back.
i think i answered my own question after further googling it seems the Rs4s from 97 onwards has a dual mass flywheel
:D
My RS4S is a 98 and as i have the flywheel out sitting next to the gearbox on the floor, i can tell u its definately NOT a dual mass flywheel. The noise is prob the throw out bearing. Mine was noisy.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
