Hi all,
Pop quiz - what should the oil temperature gauge on an R32 GT-R read?
Mine sits at the bottom (70 degrees) all of the time. Is this normal or abnormal? If it's not right, where should I start looking for the fault?
Cheers!
Mike T
Probably not working, they aren't known for their accuracy anyway, it should read the approx same temperature as the coolant temp (-/+ 5C) because oil and water both go through the oil/water separator (factory oil warmer/cooler). You should be seeing the needle starting to rise above 70C about 10 minutes into a trip.
I can think of 4 things it could be.
#1 Gauge isn't working
#2 Oil temp sensor isn't working (might work with a good cleanout)
#3 The wiring between the above 2 is damaged somewhere
#4 Thermostat is stuck open or you have a Nismo thermostat (opens at 62C) which isn't allowing the coolant (and oil because of the oil/water separator) to get up to temp
Cool - thanks! I hadn't thought of the relationship between the oil and water temperature.
On a related note then, i'm amazed at how quickly the water temperature gets up to the centre of that gauge's range. It's only a minute or so, two at the most and then it's at operating temperature. It then remains there solid as a rock.
Again, is this normal RB26DETT behaviour? To the best of my knowledge it's an unmolested stock standard engine (R32 V-Spec... so it should be stock) with only 67,000 on the clock.
Apologies if all of this is a bit 'noob'ish' - I've never owned a Nissan RB engine before. I'm also not a mechanic (I'm a construction professional).
Mine sits at 70 when warm, always. I use that as the "its ok to go hard now" mark, as you know the motor is properly up to temp (unlike the water temp gauge). On track days i saw it go as high as 110 before i got an oil cooler.
I have an aftermarket oil cooler which is controlled by a thermostat, but I still have the factory oil warmer/cooler fitted. Once the coolant is fully up to temp (85C) takes about 15mins of driving in summer, or 20+mins in winter, my oil will sit on approx 85C (factory gauge). But the oil temp always lags behind the coolant temp by about 5C, if my coolant temp is 75C for example, my oil temp will be 70C (which I'm assuming is the work of the factory oil warmer matching the oil temp to the coolant temp)
Cool... Did you use a Nissan cooler, or did you go aftemarket?
Coolant temp wise, does yours get up to temperature really quickly?
I have the factory nissan oil/coolant heat exchanger in place, and an HKS kit with filter relocator.
Re: coolant, the gauge gets to the gauge midpoint quickly - but remember what moodles said about that.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
