Any idea on how much it costs for the hardware and software?
I bought the cable directly from UpRev's website.
The generic Osiris Standard package, which is purely for flashing a file prepared by a tuner and emailed to you is US$500. This is limited to 3 flashes - additional eFlashes then cost US$50 each.
The Osiris Tuner package, which allows you to do the tuning yourself, is US$700.
Because we're dealing with JDM, I took the safe approach when I bought mine. The first thing I did was buy the Cipher package for US$200. This was a relatively cheap test to see if it would identify my ECU so that I can then liaise with UpRev to determine if the Osiris package would support my ECU. It did and so the only thing I had to pay for was the upgrade cost to the Osiris Tuner which was just the difference, therefore, US$500.
Forgot to mention: The software is free. The money is all in the hardware.
Edited by The Max
  • Replies 52
If your referring to Uprev.
Osiris Tuner is $700 (this one allows you tune your car yourself).
Osiris Standard is $500 (Uprev themselves do the tuning and mail it out and you can update it via PC)
Osiris Flash $300 (You mail in your ECU and they do magic and send it back)
:D
Lol just noticed your post after I did mine.
Question for you.
I know Uprev requires the ECU Number which Nissan can retrieve from the VIN. Did you have to give your ECU Number? I ask because I'm pretty sure Nissan Australia won't be able to give me the ECU Number being an importn which means I have to contact Nissan Japan.
Did you have any troubles?
Question for you.
Who the hell told you that rubbish?
Their consult can read everything your ecu and trans ecu (if you have an auto) have to offer and is the same hardware/software that all Nissan dealerships around the world use.
EDIT: My Cipher cable displays the ECU number automatically when I connect it.
Edited by iamhe77
You can go to Nissan and they can use FAST to see your ECU part number- if they are feeling nice on that given day. They are not suppose to give that info out. Alternatively, you can use EPC data and put your VIN in there. Navigate through the menus and you'll find the ECU part number. It will start with 23710-XXXXX
I did the process for my car about a year and a half ago, and I'm in the process now for a Pathfinder.
Cheers for that info, that makes sense. I realise alot of their things are global but wasn't entirely sure. :-)
Cheers as well for your help man. I will see how I go. :D
Maybe u thinking about BCM and immobilizer code?
Maybe I just fail actually... :whistling:
I also didn't realise that CIPHER could pull the data. I remember when I was on their site when I first got the V, in their FAQ it mentions that to get the ECU number, find someone with CIPHER which will give the VIN and contact your local Nissan/Infiniti dealer.
Obviously things have changed since then and maybe the website needs updating?
I tried EPC Data and no results found for my VIN. All good though, I probably won't get this for awhile anyways. :-)
Edited by ka86
Nothing's changed. You still use their Cipher to pull the data. What they're telling you is to find someone with a Cipher cable (as a minimum) who can pull that data for you, as opposed to taking the US$200 gamble like I did and bought a Cipher not knowing if it would pull the data or not.
It wouldn't sound very nice of them if their FAQ said "Buy a Cipher and hopefully you can extract the data."
re: EPC data, you probably just didn't enter it in the right format. You can go into the details and just search via model code- example- CPV35 auto gearbox runs 23710-AM905, AC610, CM46A in chronological order.
You can PM me your VIN, or find someone to hook uprev up, or go to Nissan.
Fair call that makes sense. I didn't realise Cipher pulled the ECU number but I see what your saying. :-)
Lol you were right, I took out some of the numbers and mananged to figure it out.
I got the ECU number, its 10 Characters long.. apparently $1721 USD (not that I'm buying lol) .
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
