I am 16 living in SA and i own a 34 non turbo skyline, due to the fact i cant drive turbo..
i am trying to do it up and make it the best it can be, what things will i have to do to put a subaru momo steering wheel on it, also what should i do to give it a bit more power without being obvious so i can avoid getting defected, also what is legal height and where do i measure from
thanks guys
theres a pic of the car give me your thoughts on other things i can do too
https://www.sau.com.au/forums/topic/408396-need-advice/
Do nothing, spend nothing.
Drive it until you're allowed a turbo then sell it and buy a turbo.
In the mean time, take extra, extra, extra good care of it so you get max $$$ when you sell it.
https://www.sau.com.au/forums/topic/408396-need-advice/#findComment-6515254
Yup & keep a log book (backed up by receipts) of all services :)
https://www.sau.com.au/forums/topic/408396-need-advice/#findComment-6515297
its 10cm from the lowest point of the car
Whats your budget for engine mods? Unless you have thousands then dont bother- Your dollar for power output is not worth it comapred to a turbo car.
But if you have the money to spend then extractors, exhaust, compression- Not sure what other really? Susspension, sway bars, good rubber and genral maint should be first on the agenda-
But yer.......look in the NA section mate- But like i said- if you have cash then you can do anything
https://www.sau.com.au/forums/topic/408396-need-advice/#findComment-6515933
The 3 steps to a better performance car:
1. Make it stop
Get the best brake setup you can, including slotted rotors, braided brake lines, high performance pads.
2. Make it handle
Fit lowered (NOT super-low) springs, good quality shock absorbers (I reckon Bilsteins are about the best going), upgrade sway bars, urethane bushes.
3. Make it go
N/A, you probably can't do much more than a set of extractors, maybe a slightly larger (3") exhaust system.
If you get the first 2 right, you often don't need the third.
And for goodness sake, learn to drive the damn thing. Nothing much beats a good quality advanced driving course. (Most driving schools only teach you how to get the licence, not how to actually drive)
Lastly, don't drive it like a dick - you are simply asking for the attention of the police.
https://www.sau.com.au/forums/topic/408396-need-advice/#findComment-6516061
leave as is, as you will need a RWC when you sell it if you mod too much it will just be a pain in the ass to get..
if you leave stock and look after it you will most likely make more from it than you would by modifying it being NA.
save all that $$ for gtr when your off your p's :D
https://www.sau.com.au/forums/topic/408396-need-advice/#findComment-6516116
1. Make it stop
2. Make it handle
3. Make it go
3" on a NA 2.5L engine is just plain stupid, unless you want to let the cops 3 suburbs away know you are coming.
https://www.sau.com.au/forums/topic/408396-need-advice/#findComment-6526488
that is only half the law. 100mm is the minimum ground clearance, that doesn't relate to how much you can legally lower a car.
(for qld anyway), when lowering a car you must maintain at least 2/3rds of the original suspension travel (measured between bump stop and metal stopper). plus the amount lowered must be the same front and rear. so you can't take a 4wd hilux and lower it to 100mm off the ground and expect it to be legal.
https://www.sau.com.au/forums/topic/408396-need-advice/#findComment-6526584
nothing, i have owned my R34 25GT for 2 years now and have donenothing except buy original GTT model rims for an unbeatable price.
I got a year left on my Green Plates ! and most of my savings are going towards something
turbocharged !
Only dollars you should be putting towards it are maintenance costs (oils, rubber bearings, break pads ETC)
Edited by starwarz
https://www.sau.com.au/forums/topic/408396-need-advice/#findComment-6526643
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
