So I took my newly acquired R32 GTS-T to a local mechanic today for a blue slip(as rego ran out over 3months).
He called an hour ago and he was scared to lift it up on a 2post lift, as he said the suspension would fall out. I explained it has adjustables in it and has all been professionally fitted and so its safe, it would not fall out :P
After a bit he called back saying its not going to pass because it has a BOV and a pod filter and that you are not allowed them...
I asked well every turbo car has a BOV, so how can it be illegal to have one? (he said he doesn't make the rules) and for the pod filter he just said you are not allowed them....
I'm a bit confused, how can this be?
He didn’t ping me for the loud exhaust or thats its super low but pings me for stupid things like this^ :(
I'm heading back after work to get in writing exactly what is wrong because this to me seems outrageous.
PS. I only moved to Aus from NZ afew months ago so not entirely sure how it works here...
https://www.sau.com.au/forums/topic/408505-went-for-a-blue-slip-today/
  • Replies 42
boggles, as in it does the same job as if it had a standard box filter. infact the car would be more economical and have less emissions with a pod filter rather then with the standard box filter... its f**ked up
i understand where your coming from, and sorry for snapping a little.
i personally always ditch my standard air box, alot of people like them for the sound. i always did. any who as your NSW, ill let you take over with the legal stuff.
have fun boys and play nice!
haha yeh well theres me being to frustrated as Ive never had to come across this before (as in NZ law is fine with atmosphere BOVs and pod filters).
anywho........
I have to change my point of view as I will consider my self lucky that that was all that was wrong in his eyes as it could have been way worse. and TBH changing to pod and BOV is easy enough.
If only we had the laws as NZ.
If only.....
hmmm [rolled.
anywhoooooo, here in strlya they dont like of we have sporty stuff. so they made a bunch of rules to say you cant have specific things!
you have 2 options.
recirculate bov and put stock airbox in
recirculate bov and build a cover for the pod. the pod has to be enclosed and removed from the chance of "catching on fire" to be deemed legal.
toodeloo
Skylines dont have BOVs from the factory as such, its known as a recurculation valve and the only way to be 100% legal, refit the factory valve and betcha you will notice no change in performance
Thanks Hadouken & StevenCJR31. Man these strayin laws are crazy! I wonder how they though a pod filter should be deemed illegal....
anywho:
When I went to pick up the car, I spoke to a different guy who loves Skylines and he just said its a stupid law but thats what it is.
So I actaully found the original 'BOV/recurculation valve' in the boot and fitted it. and guess I'll have to shell out for a intake box :(
here's a pic of the original next to the aftermarket:
There is original R32 aircleaner boxes for sale all the time on SAU and ebay real cheap. . . .and just to mess with you laws vary from state to state , for example you can have a pod filter here in western australia as long as its secured
omg are you serious, hahaha. Thanks again SteveCJR31.
I found out I could be able use the after market one. I just need to feed the hose into an intake box. Is this right? see pic^
Edited by niknac
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
