R33:
GTS S1 Nismo bonnet
S1 ES Style bonnet
S1 TS Style bonnet
S2 R style bonnet 97 model
S1 BN Style fenders
GTST Do-Luck front bar FRP
GTST Do-Luck rear bar FRP
GTST Do-Luck Side skirts FRP
GTST JUN front bar FRP
GTST INGS Front bar FRP
GTST JP front bar FRP
GTST VS Style side skirts FRP
GTST VS Style rear bar FRP
GTST UR Style skide skirts CF
R34:
GTR Nismo style bonnet CF
GTT Nismo style bonnet CF
GTR/GTT OEM style boot lid CF
R34 GTR OEM Front lip with undertray
GTR front bar with lip FRP
GTR front bar without lip FRP
GTR front lip CF
GTR Side skirts extension CF
R34 GTR Z-Tune Front bar (Dry carbon available as well)
  • Replies 291
Can i still place an order? I thought this was closing on the 19th.
If possible, i'd like:
A set of cf wind deflectors for r34 gtt.
R34 gtt cf radiator guide.
PM payment details if this is ok.
The ETA is 6-10 weeks mentioned by supplier IF I order before the end of this month. They have a customer preparing to place a full container load which will set us back if payments are late. I'm also in the process of talking to DHL to have the container loaded onto one of their ships.
R33:
GTS S1 Nismo bonnet - $490
1995 S1 ES Style bonnet - $490
1995 S1 TS Style bonnet - $490
1997 S2 R style bonnet - $510
S1 BN Style fenders - $360
GTST Do-Luck front bar FRP - $250
GTST Do-Luck rear bar FRP - $250
GTST Do-Luck Side skirts FRP $200
GTST JUN front bar FRP - $250
GTST JUN Side Skirts - $200
GTST Jun Rear bar spats - $140
GTST INGS Front bar FRP- $250
GTST JP front bar FRP- $250
GTST VS Style side skirts FRP- $200
GTST VS Style rear bar FRP- $200
GTST UR Style skide skirts CF- $200
R34:
GTR Nismo style bonnet CF - $490
GTT Nismo style bonnet CF - $490
GTR/GTT OEM style boot lid CF - $360
R34 GTR OEM Front lip with undertray - $350 - 100% Pure CF available as well
FRP GTR front bar with CF lip - $320
GTR front bar without lip FRP - $200
GTR front lip CF - $240
GTR Side skirts extension CF - $300
R34 GTR Z-Tune Front bar (said to have weigh under 5KG) - $1000 or $1300 for dry carbon
Anyone keen on bonnets or front/ rear bars or skirts?
I HAVE PMD U BUT ALSO KEEN IF YOU CAN GET
r34 gtt top secret carbon fibre bonnet
r34 gtt boot lid in carbon
r34 gtt rear tail light covers
mirrors not the poxy covers - like a ganador or craft square copy??
interior stuff would be fkn awesome as well
Edited by Shuz GTR33
Any chance of sum interior panels for 34, aircon switch panel fascia, gearshifter surround ect?
Not at the moment, but I do have plans to send the bits over to get them moulded up. I'll be sending in due time:
- Auto Gear surround
- Center Air vents
- 2DIN Head unit surround
- That big piece in the center that surrounds the A/C and head unit
- Climate Control fascia
If someone has a manual R34 surround and could spare it for up to 2 months, I'll also get that molded up.
I DO however have a R34 arm rest/ center console unit that should be finished moulding and onto production soon, although with another supplier so this may come earlier than this GB itself. PM me if your keen on it.
Current deposit as of now:
Plattsy - R33 GTST Front grill - Payment Pending
XKLABA - R34 eye lids, 34 jun high stands, rear bar diffuser addon 34 GTR - Payment Pending
stompy - R33 mirror cover, R33 GTST front grill - Payment Pending
ADUBZ - R32 nismo gts gtr bonnet lip, R32 nismo boot lip - Partial Deposit Received
enka - R34 GTR full CF wing - Payment Pending
Four-Twelve - R34 GTR OEM rear bar add on - CONFIRMED
TM7GTR - R34 GTR wing, FRP body, CF blade - Payment Pending
SS- - R34 GTR wing, FRP body, CF blade - Payment Pending
seriesII - R33 eye lids - Payment Pending
photaii - RB26DETT cam cover, r32 gtr cooling panel, r32 boot lip - CONFIRMED
def_jamz112 - R34 Wind Deflector, R34 GTT Cooling Panel - awaiting on personal details
Hey man, if the container has not happened yet i can finally jump on board and get the 34 GTR wing FRP with CF blade?
Oh I forgot about the one I was going to give you, I took it to my local beaters to get a few quotes and it was honestly 2 x more than a brand new one haha. Yeah man it's not too late. PMed
Haha that sucks man! Ill check PM :)
Edit - No PM? :(
Re-Edit - I checked too fast!
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
