  • Replies 291
All parts are ready for pickup, most of you who are picking up would have been contacted, if not PM me.
Some parts have been damaged during shipping and I am currently trying to get a replacement sent. Damaged parts include:
- R34 Eyelids
- EG Spoon Lip
- ONE pair S2000 Side skirts extension
- S15 interior replacement
- GTT Cooling Panel
- R32 weathershields
Those who have ordered the bits that have been listed damaged above, will be contacted shortly later on. Those who require shipping, have been or will be PMed the total outstanding amount and shipping cost.
picked up my items yesterday. not too bad. took some photos for you guys.... hopefully fitment is pretty good.
I would have thought that the headlight intake would have had tabs on both sides but there isn't. We'll see how it goes when I try and fit it on and see how it goes on the track.
not much to say about the coilpack cover. looks ok. hopefully the holes line up ok.
I attempted to fit my r32 dmax style roof spoiler tonight with no luck :( It doesn't sit flush so I kept pushing down with sikaflex with a helper waiting but its so curvy that it wont stay down in all places at the same time, I had my tie downs ready at the wheels to hold it firm against the windshield but it was to fiddly for it. Is anyone in the Sydney region that is willing to help me out? Or any tips? Is it safe to use a heat gun perhaps on the spoiler without ruining anything? Lost here....
I think my n1 boot lip will fit okay, haven't attempted it yet but I'm hoping it wont be as bad..
Also when will the damaged in transit parts be estimated to be made up and sent back here?
Still waiting to hear from supplier.
As for the roof wing, check out this thread on JDMST:
http://forum.jdmstyletuning.com/showthread.php?45280-dmax-s15-roof-wing-help
http://forum.jdmstyl...-roof-wing-help
Thanks I will have a crack at it again sometime this week and when its all done will post up some photos. Might get some different stronger sikaflex too and try that out. Was using 227.
Will be doing your order soon plats, packing it properly and securely is the main problem right now. Do-able, though I'm making about 15 custom boxes from flat cardboards that won't crush, which is a pain. Got a few of the 33 grills out.
Recieved my R33 CF GTR style front grill yesterday. Item was well packed lots of bubble wrap to keep it safe.
Item itself I was happy with very light and the carbon was decent.
Fitment on the other hand was the downside, the grill will not fit without removing the rear tabs sticking out and doing a little DIY to make it sit on the car how you want it too. Anyone who is waiting on theres will know what I mean when they try and fit it on the car.
The grill itself lines up fine and once in place looks great fitment is good after DIY is finished.
Overall happy with the item and the result.
you just cut them off?
Yup i removed all 4 tabs. The top ones can probably be left on but the bottom ones have to go. As each grills tabs will probably slightly different angle/width i suggest you assess which ones need removing.
I found it easiest remove all 4 as i can then place the grill how i want it and not have the tabs restricting me.
The back tabs can be cut off with a dremel / wire cutters / flower cutter basically anything with a sharp blade and handles has the tabs are fiberglass and wont be hard to cut through.
Edited by DarkRyda
forgive me for being dumb here, but if you removed all the tabs how did you fit it man?????!
Imagination and creativity =).
I drilled 4 holes at the back, two at the top of the grill where the tabs used to be and another two at the bottom next to the mesh screws. Then you zip-tie the grill to the headlight. Placement of the holes and the Zip-ties are most important or it wont fit properly.
You could also go to bunnings and get 2 U-Shaped brackets bot 1 on each side and attach that to the headlights. With doing this the U brackets must be the correct size or the grill will stick out to much. The ziptie option is probably the easiest and cheapest.
Wow dude you car is porn. What rims are you running?
Thank you. PM sent as this question is off-topic
cool. mines a white car so itll stand out like a bitch if it dont fit
The fitment is good pretty much perfect if you install it correctly.
Btw don't bother trying to zip tie it from the mesh it wrecks the mesh and doesn't align properly, so save yourself the trouble as I tried it and it didn't work at all.
Just a note the mesh comes silver I painted mine matte black with a satin clear. Maybe since your car is white silver mesh would look better.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
