  • Replies 45
Have you had a chance to measure temps yet Hayden?
Considering doing this and trying to work out if the size you've picked is big enough, and if it's not where to fit something bigger :unsure:
I'm halfway through fitting up the temp gauge, so I should have some info soon (finding time is the problem unfortunately)
One temperature variation I have noticed is the outside ambient temperature display in the dash...
After the car's been driven & parked for a short time, the outside temperature shows high 30's or low 40's thanks to the temp sensor sitting directly above the oil cooler core. :O
I'll get around to relocating it one day.
My oil sits around 87-90 degrees, and the water 76-80 on the freeway with the Nismo thermostat. That is with a 30 row 12an oil cooler. I guess the Greddy oil thermostat is set a little high. I wonder if the water-oil cooler is affecting it's operation...
I have still seen 118 degree oil temps at PI, even though the oil cooler has a 14 inch thermo running flat out. You can never have enough cooling at the track as I found out.
Great story. Was quite entertained!
Hows it go; Greedy pays twice!
AND
You get what you pay for!
Made in YumCha not so good, not so love you long time....lol...
Well done on sorting it all out in the end.
Years ago I was told that cooling the oil is more efficient than a radiator at keeping an engine from cooking. I never believed it till I put one on a V8 with chronic overheating issues. The core was approx 200 x 300mm (sold by a truck spare parts place to "cool a Mack" - I lol'd at him). So put it in & it instantly fixed my overheating problem. In fact I reckon I could've run without coolant, except I wanted the heater to work. Had to block the airflow (to the cooler) in winter so the engine had a chance to get to operating temp.
The one Hayden chose looks plenty big enough to me.
Edit: to clarify, mine didn't have a thermostat. That would've been a better idea, but meh, cardboard worked ok.
Edited by Commsman
Cheers Hayden. Be good to see how it goes.
Where did you mount it mate? Got a photo?
Thats what I'm interested in. But you havent got one in your Stag yet do you?
No I don't, but I also don't have cooling issues, yet. If there was such a thing as a finned sump, it would probably provide all the extra cooling a modified road car would need. (Not talking track days here.)
Is there room somewhere out of the front airstream to mount a cooler? That would radiate a fair amount of heat by itself, or a small fan (or 2) could help (thinking computer case sized). I don't think there's room in front of the radiator in my car either, so one day could have to look for alternatives.
Anyone else noticing a slight handling change everytime they add more weight ahead of the front axles?
Edited by Commsman
Nah thats cool Craig. I'll pull the bumper off when I get back and see what's what.
Tells me we only need a little one, which should be easier to mount. Say a 10-13 row. Just Jap have some really good pricing on the ones that Hayden used here, and there are some decent adaptors on ebay. Should be able to get something half decent for ~$150 plus hoses.
Look for a sandwich plate that allows you to angle the lines to/from it at 45deg like the Greddy ones.
Try to buy one similar to this: http://bit.ly/TJfXJw
If the adapter is one that only has the inlet/outlet coming out at 90deg to the filter, chances are you'll foul the hoses on something like the aircon lines...
You can get the grex thermo plate with a the two sensor bolts for about $140 delivered from the US. Scott has the details. Or do what I did and wait for a good deal to pop up. I think there is a hks cooler with sandwich plate for a pm35(same thing) on IM ATM......works out to be about $450 delivered.
I'll check out the US deal Craig, thanks. The one Hayden linked to looks like it'll be fine too.
GCG have them locally, but a bit pricier: http://gcg.com.au/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=1132&category_id=201&option=com_virtuemart&Itemid=101
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
