  • Replies 45
Have you had a chance to measure temps yet Hayden?
Considering doing this and trying to work out if the size you've picked is big enough, and if it's not where to fit something bigger :unsure:
I'm halfway through fitting up the temp gauge, so I should have some info soon (finding time is the problem unfortunately)
One temperature variation I have noticed is the outside ambient temperature display in the dash...
After the car's been driven & parked for a short time, the outside temperature shows high 30's or low 40's thanks to the temp sensor sitting directly above the oil cooler core. :O
I'll get around to relocating it one day.
My oil sits around 87-90 degrees, and the water 76-80 on the freeway with the Nismo thermostat. That is with a 30 row 12an oil cooler. I guess the Greddy oil thermostat is set a little high. I wonder if the water-oil cooler is affecting it's operation...
I have still seen 118 degree oil temps at PI, even though the oil cooler has a 14 inch thermo running flat out. You can never have enough cooling at the track as I found out.
Great story. Was quite entertained!
Hows it go; Greedy pays twice!
AND
You get what you pay for!
Made in YumCha not so good, not so love you long time....lol...
Well done on sorting it all out in the end.
Years ago I was told that cooling the oil is more efficient than a radiator at keeping an engine from cooking. I never believed it till I put one on a V8 with chronic overheating issues. The core was approx 200 x 300mm (sold by a truck spare parts place to "cool a Mack" - I lol'd at him). So put it in & it instantly fixed my overheating problem. In fact I reckon I could've run without coolant, except I wanted the heater to work. Had to block the airflow (to the cooler) in winter so the engine had a chance to get to operating temp.
The one Hayden chose looks plenty big enough to me.
Edit: to clarify, mine didn't have a thermostat. That would've been a better idea, but meh, cardboard worked ok.
Edited by Commsman
Cheers Hayden. Be good to see how it goes.
Where did you mount it mate? Got a photo?
Thats what I'm interested in. But you havent got one in your Stag yet do you?
No I don't, but I also don't have cooling issues, yet. If there was such a thing as a finned sump, it would probably provide all the extra cooling a modified road car would need. (Not talking track days here.)
Is there room somewhere out of the front airstream to mount a cooler? That would radiate a fair amount of heat by itself, or a small fan (or 2) could help (thinking computer case sized). I don't think there's room in front of the radiator in my car either, so one day could have to look for alternatives.
Anyone else noticing a slight handling change everytime they add more weight ahead of the front axles?
Edited by Commsman
Nah thats cool Craig. I'll pull the bumper off when I get back and see what's what.
Tells me we only need a little one, which should be easier to mount. Say a 10-13 row. Just Jap have some really good pricing on the ones that Hayden used here, and there are some decent adaptors on ebay. Should be able to get something half decent for ~$150 plus hoses.
Look for a sandwich plate that allows you to angle the lines to/from it at 45deg like the Greddy ones.
Try to buy one similar to this: http://bit.ly/TJfXJw
If the adapter is one that only has the inlet/outlet coming out at 90deg to the filter, chances are you'll foul the hoses on something like the aircon lines...
You can get the grex thermo plate with a the two sensor bolts for about $140 delivered from the US. Scott has the details. Or do what I did and wait for a good deal to pop up. I think there is a hks cooler with sandwich plate for a pm35(same thing) on IM ATM......works out to be about $450 delivered.
I'll check out the US deal Craig, thanks. The one Hayden linked to looks like it'll be fine too.
GCG have them locally, but a bit pricier: http://gcg.com.au/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=1132&category_id=201&option=com_virtuemart&Itemid=101
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
