  • Replies 72
Posted Images
So quite simple, who has the coolest numberplate, removing the (no doubt unstoppable) discussion on if having a personalised numberplate makes you a knob.
My plates read BCNR33. Got them with the car.
Saw BNR34T on an urban 4WD of some kind (Audi if I recall) the other night. lol'd.
Saw the plates FOMOCO on a Toyota Corolla today.
FOMOCO is the acronym commonly used for the Ford Motor Company, specifically their racing parts and muscle cars.
Edited by Amaru
Saw "BNR-33T" (nsw plate) on some kind of softroader. (pathfinder maybe???)
^^^I put this in the Plates that make you LOL thread.^^^
Coincidence ???
Flamin' Mongrels takin' all the good plates. NO FAIR !!!
Sinista's Plate is pretty damn fine as far as cool plates go.
Coincidence ???
hahaha as my post above, saw the same car :P
Was it 34T or 33T ?
Definately was NSW plates, but I can't be sure of model of car as I was still asleep on the way to work.
(dumbf**k o'clock)
I think it was redish ish in colour?? :blink: maybe...
regardless it was definately a WTF? moment. LOL.
Was it 34T or 33T ?
(dumbf**k o'clock)
It might be someone who used to own one and wants to keep the plates (for a future car maybe?) so has just chucked them on another car instead of paying to store them.
Wow, so BNR34T and BNR33T are both out there, being used on softroaders and not for their true purpose.
Makes baby Jesus cry. (he builds hotrods after all).
Tis a shame that these people do this and not pass em on but I guess a plate is just a plate.
A numberplate, by any other name, would smell as rich.
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
