Hello everyone.
Picked up a stock standard example of an S15 after looking for several months. It is 100% straight, all original panels and all original paint. There are lots of accident damaged S15's out there unfortunately so it usually takes a while to find a nice one (if you know what you're looking for).
My main focus is response and handling. The tuning concept for the car is "Bakemono". The build will predominately utilise Japanese parts for authenticity.
The car is being built for a purpose, that is, it will be a sleeper. There will be little focus placed on aesthetics. The car will be left looking relatively stock on the outside so I don't draw attention (attention can be good, but it can also be bad and come from the wrong people).
I've got a stack of parts waiting to be installed, but here is the most recent arrival.
I have some more stuff in transit from Japan at the moment and some other current inventories.
Will update the thread every so often once things begin progressing.
https://www.sau.com.au/forums/topic/409507-bakemono-nissan-s15-build-thread/
Here is the first package I received from Japan and the quality of the items is phenomenal.
Especially impressed with the HKS Hipermax III Coilovers, definately worth the money. Unfortunately, I believe they have been discontinued now.
Front set.
Rear set.
HKS Tool Kit (came with the coilovers). I like how they threw in some zipties haha.
Rear upper camber arms are the pillow type. For the Rear Toe Adjustor Rods and Tension Rods, I elected to go with the rubber bush type as this car will be predominately street-driven. The rubber bush ends will be quieter and won't wear out as fast, and they have slight play in them due to the flex of the rubber (which is actually ideal for the street).
Tension Rods (aka Front Castor Rods).
Rear Upper Camber Arms
Another package arrived from Japan a few days ago
Top Secret Shift Knob
and...
HKS Catback System.
Once again, the quality of all the HKS stuff I have received so far has been exceptional. Have been very impressed with the workmanship.
What dump and cat are you going to run Bentji?
I was going to run the HKS GT Extension Kit but Streeter told me it had been discontinued. Would of been ideal as I would have had way more ground clearance. Plus, the design was very good for response.
Instead, I bought a used CES Racing Front/Dump Pipe off a wrecked S15 (had a slight crack near one of the welds, but mechanic said he would weld it and it will be fine).
The mechanic has a contact who makes the hi-flow cats and he recommended I get a 200 cell one.
This arrived in the mail not long ago....=D
Also, 22 days until I can get my full licence.
Update on the car:
Car has been sitting since the trackday at Wakefield on July 26th, so safe to say all the fuel would be stale by now.
Checked tyre pressures and they're down to 20psi. Brakes still haven't been organised and are metal on metal, so need to get that organised.
Going to DIY the coilovers/alignment arms with a member from JDMST!! This will probably happen sometime in November once I'm finished uni for the year.
Got a CES Front/Dump Pipe lined up and need to get a Hi-Flow Cat
Thought this sticker was lulzy, so I played up the stereotype of S15's being used as drift cars.and I installed it.
Tomei N2 Oil Pan
I like how Tomei has included some English instructions (for people like myself who can't read Japanese)....and two stickers :D
Hey Benji, Although your car isn't heavily modified so it shouldn't be too much drama try to keep things stealth and no sticker etc.... The cops around here are pretty hard on imports and you don't want any un-necessary attention! Also, the DIY thing will apply to the exhaust, brakes and suspension as it is all pretty straight forward. Like i said, try GSL if you want good brakes at a cheap price, if you are sticking to all name brands i have ENDLESS pads and rotors in my car and they have been nothing but awesome!
Yeah didn't really think of that....probably not a good idea having that sticker on there (e.g. if a HWP has a look inside the car).
Also, assuming the hi flow cat will be fully flanged up, itd be as simple as just putting bolts in wouldn't it? Or do you have to use sealant as well?
Yeah just been researching brake rotors etc and still weighing up the pros and cons. How are the endless pads and rotors for the price?
Yeah the thing is literally bolt up, really easy to do! Just use new gaskets! You could seal them up but i wouldn't as when it comes time for a clutch change or if you want the exhaust off for some reason it just makes a hassle, just bolt it up nice and tight and it will be fine, they are a direct swap in most cases.
The DBA. RDA etc will all do the job, i have been running stock rear rotors for the entire set of endless pads and the held up fine, the front rotors are endless though..... I would suggest the DBA 4000 series rotor with a decent pad, however i will be trialling the QFM pads as they are cheap and get a solid review!
nice one benji!
quick question, why did you get an S15 and not another S13, and build it up?
Yeah, I got an S15 because I couldn't find another S13 in good condition....finding an S13 that hasn't been bent from an accident is like finding a needle in a haystack.
S13 is definately a more fun, enjoyable car though, providing the condition is good (like my old one). Looks cooler + has more character than a S15 i.m.o
In all honesty, should of looked to import one from Japan, but couldnt be bothered going through the hassle.
Wow! There is some awesome stuff going into this car.
What diff are you running at the moment?
Thanks =).
Just running the stock Helical LSD at the moment.
Might go for a Nismo GT 1.5 way later on down the track, but not necessary yet.
Nice and look forward to seeing your power mods. Go for HKS GT-RS low mount turbo, it is a match in heaven for stock SR20. I used that setup in my last s15 and absolutely loved it and looks nearly original under the bonnet! Here is a photo of it :
  • Haha 1
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
