I did a similar conversion on my R32 Skyline, and all up it was around $10,000 for me too.
That included:
Complete Series 2 RB25DET (with loom & computer)
R34 Intercooler
CES Twin dump pipe
STR Adjustable Exhaust Cam wheel
Extreme Clutch & lightened flywheel
5 stud conversion
New 17" Rims & Tyres
R33 Brakes
LSD Diff
Apexi Pod
GReddy Turbo timer
Boost gauge
+ Labour
A fair amount of money, but well worth it
same, car cost me nothing, didnt owe anything on it, sentimental value was super high, well worth it for me
this is justn a price list as everyone keeps on asking the same thing about converting or bolting a turbo on. this is to either give people an idea, or scare them away from doing it, because its not cheap so it helps them plan out what they really want to do and if its worth it to them or nots
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
