Hi all
Unfortunate incident with the beloved. Minor error with the old wheel spacers. Does anyone know or have heard anything or know a v35 coupe that has been written off or is being used as scrap that i could source a front left fender off.
Extremely desperate as i cant drive without one.
Please help!!!!
Any reply is greatly appreciated. Thanks all. I know youll help a brother on need!!! :)
Sorry to hear about that Sam. Best bet is to call a few of the bigger auto wreckers and get them to put a call through their CB networks. Try Japanese Import Spares at Windsor Gardens too - they stock various V35 bits. I also read in one of the spotted threads about a red V35 in a pretty bad accident on Lower North East Rd a few weeks back - so there may be a fresh wreck floating around at one of the import/car part yards.
  • 4 years later...
