Hi everyone,
As the topic state, I have some stuff to sell. If you see anything you like from the list below, just PM me about it. I'm happy to bundle any of the parts also.
- OEM Coupe (2003) L+R Headlights (no globes or ballast) - $350 pair
- OEM Side Indicators (no globes) - $20 pair
- OEM Infiniti Grill - $50
- OEM Infiniti Badging (for boot) - $50
- OEM V Tube - $50
- OEM Rear section of intake box - $30
All parts are in working order, they have just been replaced by aftermarket parts and are no longer needed. The rear Infiniti badging will be taken off this weekend, hence the photos showing them on the car. The headlights are going cheap as they have no globes. Save some cash then get the right globes, sounds fair hey.
Please not I am located in Geelong. Happy to drop parts off at Melbourne V meets. Postage to interstate at buyers expense.
Cheers,
Edited by Mayo_85
https://www.sau.com.au/forums/topic/409649-fs-v35-coupe-parts/
I would like to buy the indicators please mate. Please PM me your account details and postage cost - can you bubble wrap them and put them in a $5 post pack?
Perfect. PM has been sent.
Thank you
What are you replacing all this with mate? What sort of aftermarket lights etc
Headlights are those Halo lights (black housing) from that group buy earlier in the year.
Replacing the other stuff was a Z Tube, G35 Rev-Up Airbox, Iconic Dynamics emblemless grill (satin black), smoked indicators.
The grill is probably my favorite buy, will post some pics on a sunny day.
Mad those are the lights i'm buying, same as Runner4life? aka Sam the police officer and a few other guys. Yeah i got a grille lined up just waiting for the Ebay seller to relist it they said it'd be back up for sale today. Throw some pics up on the grille when you can bro.
^^^ yeah Sam's look AWESOME in the flesh - the black on black with a dark grille looks pimp as.
I can't wait to get them, i just need to work out if my car still has the factory ballast in it and if it's f**ked/working and some bulbs too.
Bump & Update
- OEM Coupe (2003) L+R Headlights (no globes or ballast) - $300 pair REDUCED
- OEM V Tube - $30 REDUCED
- OEM Side Indicators (no globes) - SOLD
- OEM Infiniti Grill - SOLD
- OEM Infiniti Badging (for boot) - SOLD
  • 3 months later...
Are the headlight still available?
Will these fit my 01 V35 sedan?
I'm new to this, are the sedan and coupe headlights interchangeable?
Al
Sorry mate, these headlights have sold.
Al
No. Coupe and sedan headlights are
Different.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
