  • Replies 40
UPDATED LIST!!! PRICE DROP!!!
various trims $name your price
centre console brackets $1
power steering reservoir minus cap $5
centre dome light without cover $5
driver door loom $5
washer bottle loom $5
number plate lights $5
front windscreen washers $5
ignition/headlight reminder beeper $5
stock rear audio amplifier $5
sun visor clips $5
wiper amp $5
Mirror triangle cover thing - $10
drum brakes (in bits and pieces) $10 for both
Pod filter $10
front reading lights $10
HICAS computer bits $10
blower fan $10
bonnet lining $10
brake booster $10
brake pedal $10
centre console hand brake leather $10
centre console front trim $10
door sill trims x 2 $10
driver's side kick panel $10
dump pipe (stock) $10
AC evaporator $10
front pipe (stock) $10
hicas steering rack $10
passenger side a pillar trim $10
passenger rear arm rest trim $10
passenger side kick panel $10
roof lining $10
steering column (minus the bottom part of the shaft) $10
under-dash bar thing $10
under steering wheel trim $10
under windscreen cover $10
alternator - had battery juice spilt on it from the accident, might still work $10
boot rubber seal $10
catalytic convertor sensor $10
dash dimmer $10
door seal (the hard one, not the soft rubber one) - i think it's the driver's side $10
ignition loom $10
driver side door solonoid $10
flywheel cover $10
open door sensors $10
passenger fog light (lens is ok, plastic a little cracked) $10
various metal sheild bits $10 the lot
wiper switch $20
rear wiper motor $20
cluster surround $20
interior wiring (includes wiring that goes into the boot) $30
rear seat belts $20
hazard/stereo switch $20
outer door handles $20 each
fuel pump $20
Headlight wiring loom minus front indicator plugs $20
castor rod arms $20 each
hicas module $30
side mirrors $40 each (driver's side has a small crack on the side)
front control arms x 2 $40
rear calipers x 2 $70
Passenger side mirror gone!
centre console/handbrake surround gone!
2 x kick panels gone!
passenger side a pillar trim gone!
seat belt bolt covers gone!
passenger side rear seat hand rest panel gone!
  • 1 month later...
The remaining parts have been listed as a $1 NO RESERVE eBay auction - http://cgi.ebay.com....em=261147664144
I want this stuff gone! Happy bidding!!!
Only 3 hours left until the auction closes (see link above) and that's all the parts gone from my wreck! Get your bids in or miss out!
LAST CHANCE!!!!
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
