I didnt do it myself but the guy who i bought it off. Everything seems fine with the engine, but the car is running way too rich...so much smoke and smell.The engine is running low compression pistons since its was originally a rb20det. What can i do? put non turbo injectors and/or change the fuel pump?
  • Replies 46
Injectors etc probably arent going to help, more likely an ECU will...... But i must ask WHY did he remove the turbo? The RB20DET - T would be terrible to drive? (No offense)
crap power low end but it picks up like a skyline should after like 5500rpm. BTW i think there is already an ecu..u cant just take the turbo off and expect your car to run...it wont!
Oh it'll run just fine.
Might be a lil' rich though.
an NA that piks up after 5500. Far out. your on p's by the sound of it?
the only money id spend on that is to get a rb25de and bolt in.
you think there is an ECU? is this car on bricks?
go fist yourself, i want to drive a non turbo r32, f**k me right? i dont care ive been looking for a factory gts for a while now and most of them are either auto or are really expensive. They are rare...more and more r32's are off the street nowadays. The car drives fine, it just runs rich.
You said its got a non turbo computer? What colour are the injectors? pink or red?
Also a rooted o2 sensor will cause this.
injectors are greyish black
here's a picture of the ecu...it looks aftermarket : http://imgur.com/2UWCH
Looks like the NISTUNE logo and Envy Dyno.......
ye i told you it had an different computer
id also like to mention im still using the factory turbo manifold...its been modified to go straight to the dump pipe. Maybe its a bit restrictive? getting different headers will be one of the first mods id do.
haha, hit a sore point did i mate?
Sorry, your car is not rare. But... What you could do.Is grab a NA rb25de for Say $500, Bolt it in. Not only will you have a stock DE motor, But will be able to enjoy the extra .5 Lt. Win win is it not?
Otherwise you could spend money on what you currently have....And still be drving around in a low comp 2L NA
Edited by sydking
and pay thousands to get it engineered? no thanks bro
Edited by IM-32-FK
Definetly buy a rb25de motor, cheap as compared to fixing yours to run properly as will only take a day to fit of you have some knowledge. Also will go way quicker than what's in there now
Hmmm, you should watch what you are talking about. As for his suggestion of putting a proper non turbo motor in there is the smartest decision you will ever make.
As for why your car is running shit? Its because the turbo is missing doofus. And want to know another thing? Your non turbo'd car is still illegal for you to drive on your p's because it was registered as a turbo.
So instead of spitting in people's faces like a spoilt brat, just take what he says and reply in a manner as follows, no thank you, I would rather try something else
lol u driving a non turbo 4 wheel drive r33 ROFL what a joke why bother having 4 wheel drive when your car dont even have power lolololololol
Doesn't need to be engineered as its a factory motor designed for that chassis. Also awd helps heaps in wet, I know my rwd r33 has stepped a few times when you don't want it to.
Also, what's with the attitude, why bother asking for help of your not going to take it positively
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
