I didnt do it myself but the guy who i bought it off. Everything seems fine with the engine, but the car is running way too rich...so much smoke and smell.The engine is running low compression pistons since its was originally a rb20det. What can i do? put non turbo injectors and/or change the fuel pump?
  • Replies 46
Injectors etc probably arent going to help, more likely an ECU will...... But i must ask WHY did he remove the turbo? The RB20DET - T would be terrible to drive? (No offense)
crap power low end but it picks up like a skyline should after like 5500rpm. BTW i think there is already an ecu..u cant just take the turbo off and expect your car to run...it wont!
Oh it'll run just fine.
Might be a lil' rich though.
an NA that piks up after 5500. Far out. your on p's by the sound of it?
the only money id spend on that is to get a rb25de and bolt in.
you think there is an ECU? is this car on bricks?
go fist yourself, i want to drive a non turbo r32, f**k me right? i dont care ive been looking for a factory gts for a while now and most of them are either auto or are really expensive. They are rare...more and more r32's are off the street nowadays. The car drives fine, it just runs rich.
You said its got a non turbo computer? What colour are the injectors? pink or red?
Also a rooted o2 sensor will cause this.
injectors are greyish black
here's a picture of the ecu...it looks aftermarket : http://imgur.com/2UWCH
Looks like the NISTUNE logo and Envy Dyno.......
ye i told you it had an different computer
id also like to mention im still using the factory turbo manifold...its been modified to go straight to the dump pipe. Maybe its a bit restrictive? getting different headers will be one of the first mods id do.
haha, hit a sore point did i mate?
Sorry, your car is not rare. But... What you could do.Is grab a NA rb25de for Say $500, Bolt it in. Not only will you have a stock DE motor, But will be able to enjoy the extra .5 Lt. Win win is it not?
Otherwise you could spend money on what you currently have....And still be drving around in a low comp 2L NA
Edited by sydking
and pay thousands to get it engineered? no thanks bro
Edited by IM-32-FK
Definetly buy a rb25de motor, cheap as compared to fixing yours to run properly as will only take a day to fit of you have some knowledge. Also will go way quicker than what's in there now
Hmmm, you should watch what you are talking about. As for his suggestion of putting a proper non turbo motor in there is the smartest decision you will ever make.
As for why your car is running shit? Its because the turbo is missing doofus. And want to know another thing? Your non turbo'd car is still illegal for you to drive on your p's because it was registered as a turbo.
So instead of spitting in people's faces like a spoilt brat, just take what he says and reply in a manner as follows, no thank you, I would rather try something else
lol u driving a non turbo 4 wheel drive r33 ROFL what a joke why bother having 4 wheel drive when your car dont even have power lolololololol
Doesn't need to be engineered as its a factory motor designed for that chassis. Also awd helps heaps in wet, I know my rwd r33 has stepped a few times when you don't want it to.
Also, what's with the attitude, why bother asking for help of your not going to take it positively
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
    • It sounds farrrrrrr too cold at your place Duncan... Here I was thinking our 10 degrees overnight is getting cold...
    • oh yeah, reminded this morning....bin lids frozen shut too
    • In my case not, because of total reno. But yeah.
    • Did you use an electronic speedo drive? Does you speedometer read all the way to 180km?
