Hi Martin, I got my entry in and made payment for option 1, but when I went to put my entry number on my online banking description, I realised I had lost the SAU page somehow .
I then just put my full name in the payment description. Is there anyway to fix this or will you be able to identify my payment ok? PM me if you want any other details, sorry for the mishap!
https://www.sau.com.au/forums/topic/409757-sau-nats-2012/#findComment-6542924
no idea as sau vic not running event
that said Ash will most likely work it out, and if the rest of your details ok they should match it up
so the big thing is.
sau vic took home most of the prizes last year..who helping to bring them back again
https://www.sau.com.au/forums/topic/409757-sau-nats-2012/#findComment-6542933
dont stress - easily worked out :)
https://www.sau.com.au/forums/topic/409757-sau-nats-2012/#findComment-6543344
I'll do what i can! Those NSW silvias are going to be hard to beat though! SXDS15 and S14, Hawkins in JET200 and it's their home track. Having said that I should be able to keep them honest!
if it makes it easier I volunteer to steal SXD's aero from the s14...just to help you out really
https://www.sau.com.au/forums/topic/409757-sau-nats-2012/#findComment-6543510
  • 1 month later...
All moved to the Nats area, plus drive ups.
ON a plus Note I'm donating this to the vic ppl at the alpine hotel for thurs night drinks
GLENLIVET Master Distillers Reserve Malt Whisky 1 Litre
gotta love duty free prices.
byo glass and ice
https://www.sau.com.au/forums/topic/409757-sau-nats-2012/#findComment-6623104
Just a FYI having come up today with a mate there are a few points to note.
1. The Gundagai BP (Dog on a box) is CLOSED. This is my usual fill point so assuming a few of you will be planning on that also. So to get around this - get off @ the South Gundagai Exit (the first one of the Gundagai exists), and take a RIGHT from the off ramp. There is a Shell and a HJ's/McD's there rather than BP but that's how it goes.
2. There is a TONNE of roadwork. It took us significantly longer than usual to get up. So minimise your stop time at servo's if you can/fill up quickly etc. There was varying works from 40km/h to 80km/r in a fair few sections, much more than when i came up 2 months ago.
3. Few TMU's out, usual story there :)
https://www.sau.com.au/forums/topic/409757-sau-nats-2012/#findComment-6625013
Thanks for the heads up Ash
https://www.sau.com.au/forums/topic/409757-sau-nats-2012/#findComment-6625256
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
