Boys and girls,
I took my car to be dynoed as it has been running like a sack of sh%# lately at JPC in Thomastown (best guys ever).
My first run revealed 120 kw@wheels for an R33 with a full 3" exhaust, new turbo, cold air intake and boost, thats not very good at all.
Anyway after cleaning plugs, coils and playing around for two hours on the car I managed 140kw@wheels.
I have a lazy fuel pump thats on its way out and the boys on the dyno said that anything higher than 140kw starts to lean the engine out.
So, I need a new fuel pump. Any ideas, prices or places in Melbourne to get one??
I don't need a 500 horsepower pump. Just something for a mildly modified skyline
Warren, sorry I missed lunch I will go next time for sure. I'm having alot of people asking about JPC so here are their particulars below. I've been to a few shops and these guys are the best by far. I also have a friend that sells every conceivable part for imports so if you need anything then let me know. (he ended up supplying a GTR fuel pump for me)
J.P.C. Johnsons Performance Centre Pty Ltd
Turbo Reconditioning, Dyno Tuning, Hi Performance Turbo Charging
27 Lipton Drv Thomastown VIC 3074
ph: (03) 9469 2566 Motor Engineers & Repairers
They were fantastic. They know turbo cars backward. $88 for the full tune and they seriously spent 2 hours on the car.
They have a very attractive young girl (on P's) working there called Nicole. She answers the phones. She'll hand you over to the right person $88.00 for full dyno tune (3 runs), cleaned and re-gapped all 6 plugs, cleaned all coils. and did some other bits and pieces
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
