Hey,
Just wondering how far a standard r33 rb25 (ser2) fuel pump will go?
Currently running the following setup: 3" exhaust, FMIC, std turbo, std injectors, remapped ecu and 12 psi.
Will it handle this ok?
cheers
matty
Probably yes, but due to the age of the car and the pump i would be looking to invest in an upgrade at some stage just for safety anyway.... They are cheap and easy to do so no reason not too :)
hmmmm good point.
Whats the better setup in a r33?
Bosch 040 and remove the sock, mount pump as low as possible
or
Bosch 044 and adapt the standard sock to fit?
i did a 040 years ago and remember not being certain that I had it mounted as low as it could possibly be and from memory i recall seeing a 044 mounted in tank with factory sock....
How much power are you aiming for mate? Drop in Walbro will be much easier for lower power levels....
My 044 is mounted with rubber on the bracket and has a sock, better than the 040 option but depends on how much you actually need?
ive had 2 walbro's now, the 255Lph handled 260kw so that would be fine.. quite cheap too. I didnt want to take chances with the fitment, tuner fit mine in well under an hour so worth it to get done right first time.
Walbro have a good rep, with the Bosch pumps Ic heard good and bad things. Seems they can go either way depending on batch etc. I recently bought a Nismo and couldn't be happier. I'm letting a GTR pump go. PM if interested, I want it gone!
What bad things have you heard? Been pretty reliable from my experiance and many many others...............
Not saying they're all terrible, but as I said I've heard a few can be dodgey and have ha to be replaced. Read it in a couple of threads here on SAU, but as I've said I'm not commenting on personal experience just what I've read on here.
I've had a Walbro in my tank for about 4 years. I have a 044 as well - haven't heard anything bad about them except they're noisy as!!
Mine is quieter than the 34GTR pump I had.... All about how you mount it etc
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
