I wonder if the v35 or r35 afm may be an upgrade, do they have have a longer lifespan?
I haven't heard of the same issues on the forums from Z owners. However the characteristics of the AFM are most likely quite different, and we have no way of tuning the AFM table. Does emanage have AFM table adjustment, or just switch over points?
So were stuck giving the same old advice - if you have a oiled filter (K&N) get rid of it for a dry, clean the AFM in contact/afm cleaner overnight and it might come good, and look for shorts in the wiring to the loom that could cause a short and fry the unit.
https://www.sau.com.au/forums/topic/410179-afm-m35/#findComment-6550535
What component/s are in there? Probably a diode & resistor, lol.
If someone wants to post me a broken AFM, I'll try to work out if a 'field refurbishing' kit is possible. The components might only cost $2...
I've never had mine go faulty, & I've had it in/out dozens of times when playing intakes. There is something weird going on for those guys who have broken multiple AFMs.
https://www.sau.com.au/forums/topic/410179-afm-m35/#findComment-6550645
Agree 100%
I've had Rudis car logged, and there was nothing in diagnostics logged, and nothing dodgy going on with the voltage output through the test. It may be a suspect pin or solder within the ECU, or even bad earthing from somewhere. I dunno :down:
https://www.sau.com.au/forums/topic/410179-afm-m35/#findComment-6550669
If replacing the afm fixes the problem then I guess the afm's are faulty. As far as I know there is no repairing them, I have tried and failed. Grab one of these guy's old ones and have a crack if you like Leon but they are more complex than you think.
Like I said, the best option would be to replace it with a more reliable unit, yes the emanage ultimate does have various maps for z32 afm's etc I believe...
https://www.sau.com.au/forums/topic/410179-afm-m35/#findComment-6550735
So that pic is our standard AFM pulled down? Didn't know it had circuitry inside, lol. I thought all the smarts were done at the ECU end.
Pretty sure I still have my old one if you want to tinker Leon. Let me know and I'll post it up.
Yeah, send it up Ryan & I'll have a look. The problem could be simple, or not, but it's worth another go at it for the sake of the poor buggers having continual problems. And Scotty, you don't use your welder to fix these :P
Edited by Commsman
https://www.sau.com.au/forums/topic/410179-afm-m35/#findComment-6551781
I used to do component level electronic repair but this is out of my league, it is potted in a soft silicone and makes getting to the board difficult without damaging it. It is definitely not designed to be repaired, only a couple of components can be de-soldered anyway.
The circuitry would smooth the signal and probably adjust the airflow voltage dependant on temp and perhaps air pressure. It would make manufacturing the ecu and tuning easier.
https://www.sau.com.au/forums/topic/410179-afm-m35/#findComment-6551803
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
