Hi guys,
Okay I got a pod filter,
racing radiator
hd clutch
3" full turbo back exhaust+ high flow cat
boost up to 12psi
Currently getting better coil packs to fix miss fire problem
what should i do next?
Fuel pump?
Injectors?
Chip and tune?
looking at $1500 to $2000 budget
What you think guys??
Fuel pump, Nistune fitted and properly tuned.
This^^ Include filters and oil changes and new plugs as well if you already haven't done so...
Good preventive maintenance goes a long way
What happens when he can't get 100ron or E85??
If its tuned not on the edge then he should be fine to use 98 but not be flogging it, hows that different to not being able to find 98 and having to put 91 in, you just dont be flogging it , common sense
When can't you find 98?
I've never not found 98, and I've been through that many bush whacker towns with the GTR..
Would be silly to have it tuned on anything but 98 in this situation
good point, what i mean is a few octane points drop shouldnt be an issue in the rare case you cant get 100 or some eflex, if its not a daily and you want every last kw then it would help.. and most people are looking for every kw they can get for cheap..as long as it still practical for them i guess, but 98 would be less fuss.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
