Thanks guys.
This is what I have so far:
VQ35 VQ35DE (03-06)
SKYLINE (03-06): PV35/CPV35
INFINITY G35
STAGEA : PM35/PNM35
FAIRLADY Z / 350Z (03-06): Z33/HZ33
FUGA : PY50/PNY50/Y50
VQ35HR & VQ35DE 07-UP (does any one know what year these finish?)
SKYLINE : PV36/V36/NV36
TEANA : PJ32/J32
MURANO : PZ51/PNZ51
FAIRLADY Z : Z33/HZ33
How about the 2.5 models? Which coils suit these? Are the above year models correct for the models listed?
V36 (2008-) and Z34 (370Z) use the same VQ37VHR engine although I believe the V36 sedans didn't get this engine until the 2009 model. Otherwise, up until then the V36 sedans got the V35 engine.
So the 350Z (07-08) uses the same coils as the Z34 (370Z)?
PM35 Stagea, Z33 350z, V35 Skyline, Y50 Fuga all use the same coil (22448-AL615).
From 2003-2012 this was superceded with the 22448-AL61C plug for VQ35de powered Stagea, Skyline and Fuga.
No mention of V36 or Z34, so I would imagine that they use a different coil.
ok. Ive done a bit more research and have compiled this list:
Yellow Jackets part# YJ-VQ35-S1 - (VQ25DD VQ30DD VQ35 VQ35DE 3.5L V6):
VQ35 VQ35DE 3.5L V6:
SKYLINE PV35/CPV35 (03-06)
SKYLINE V35 250GT/300GT VQ25DD/VQ30DD
SKYLINE V36 SEDAN (up to 2009)
INFINITI FX35 (03-08)
INFINITI G35 COUPE/SEDAN (03-07)
INFINITI M35 (06-08)
STAGEA : PM35/PNM35 (01-07)
M35 (06-07)
FAIRLADY Z / 350Z Z33/HZ33 (Includes roadster) - (03-06)
CEFIRO A33 (99-02)
CEDRIC/GLORIA (99-04)
LEOPARD Y33 (97-99)
CEDRIC Y34 (99-04)
GLORIA Y34 (99-04)
Yellow Jackets part# YJ-VQ35-S2 - (VQ35HR & VQ35DE 3.5L V6 / VQ37VHR 3.7L V6 / VR38DETT 3.8L V6):
R35 GTR VR38DETT (08-12)
SKYLINE PV36/V36/NV36
SKYLINE V36 sedans (2009-Up)INFINITI G35 COUPE/SEDAN (03-07)
INFINITI EX35 (08-Up)
TEANA PJ32/J32
MURANO PZ51/PNZ51
FAIRLADY Z Z33/HZ33 350Z (Includes Roadster) - (07-08)
FUGA PY50/PNY50/Y50
FX35 (09-Up)
M35 (08-09)
ALTIMA SEDAN (07-12)
ALTIMA COUPE (08-12)
MAXIMA (09-Up)
MURANO (09-Up).
V36 VQ37VHR (2008-Up)
Z34 (370Z) VQ37VHR
How does this look?
  • 4 weeks later...
M35 (06-07)
CEFIRO A33 (99-02)
LEOPARD Y33 (97-99)
CEDRIC Y34 (99-04)
GLORIA Y34 (99-04)
TEANA PJ32/J32
MURANO PZ51/PNZ51
FUGA PY50/PNY50/Y50
FX35 (09-Up)
M35 (08-09)
MAXIMA (09-Up)
MURANO (09-Up).
Z34 (370Z) VQ37VHR
How does this look?
Just a correction, the Skyline V36 Sedans have VQ35HR (PV36) and VQ37VHR (KV36) engines.
PV36 are from 2006-2008
not a V36, I have a 370z, same engine though so imagine this would make for a sufficient test subject, I drive a minimum of 500km a week with a mix of highway and town driving, and i cant resist going hard in it half the time :P
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
    • Mine's a bit bigger at 70x150mm roughly. The spots are flat, just can feel the edges if I dig my nail into it. I did fix some other other ones by both using my finger to sand that small spot (I'm a bit wary of doing this and creating hot spots and a bigger mess) and I also did sand over it flat and others, but this also worried me a bit because if I create an overall low spot on the panel on paint that is good.  Correct me if I'm wrong but as long as it's flat even if I can feel the edges, I can put filler because it will all be level once I sand it? I can see myself going in a circle after sanding guidecoat with 320 grit if for example the panel is flat with my hand but because I sanded the guidecoat I could have created a low spot again somewhere. Unless where I'm going wrong is what I mentioned previously where I didn't go low enough on the grits. It's 1 step forward and 2 step backwards here haha. I'll probably need to experiment with it more. Last time I go back to bare metal lol.
