  • Replies 3.5k
Naice.
The other two kunce in the office just changed the channel, back to commercial shit, da fuq?
farrrrkin hate that, my boss is a bit of a bogan and loves the old school shit and i can't stand it. Always change it back to the J when he leaves lol.
  • Like 1
