G,day, Im after some knowledgable info.
Car is a R33 GTST running M/T Street radials, with my "drag suspension" (stock shocks w/ standard height springs) installed in the rear the car has been raised about 50mm and has given me around 1 deg positive camber (roughly using a straight edge and calibrated eye).
As it is a IRS car would this be fine to get near a 0 deg camber when it squats on launch.
I know there is more to it than rough numbers but really all Im after is a good starting point and then start adjusting from there.
Thanks, Mark.
https://www.sau.com.au/forums/topic/410931-positive-camber-for-drags/
I remember a thread on this semi-recently, in the past 4 months for sure.
I've had a bit of a search, but can't remember where it was. Someone else was asking much the same question. I'll keep looking and see if i can find it, was a few posts on the topic but i think it was in the middle of another discussion :(
I found a few but all they said was to get to 0 deg camber on squat, not what you could start around, on a yank site there was talk of 0.5 positive but that was on drag specific shocks and springs on a new Camaro.
Its a pity but I assume that people are not to keen on giving up their "secret"alignment settings they most likely spent along time working out....
Mark, you need to figure out a method to measure how far your car is actually squatting on launch.
From there, strap the car down so the suspension is compressed down that far. I'd then set the car up to still have the MINUTEST touch of positive camber.
You should then be pretty darn close to 0 when you actually launch it. As you'll have more grip then you currently have, it'll squat the slightest bit further, and that previous minute amount of pos camber becomes 0 camber.
Where I am ATM, best 60ft was 2.1
Installed stock shocks with heavy duty standard height springs, measured camber which came to positive 0.75 deg, as my camber was set at 0.75 neg on my Bilstiens w/ low King springs it is a change of 1.5 deg.
Car was raised from 340 to 380 at the rear, 40mm more height so hopefully the Drag radials will not hit the guard now.
If this doesnt work Im going to replace the low King springs for the heavy duty springs in my Bilstien shocks and set the shocks at the heighest setting.
Trying to get the car set up for the drags by just replacing the struts so I can have my normal street/track struts and my drag struts as the only thing I need to change, I can see this not working well though and a couple of trips to the tyre shop for re/re alignments between drags and circuit work.
ATM my main concern is getting the car set up for the SAU NATS airport run, weather permitting Ive got 4 Wendsday night drag days to get my sorted on.
Hopefully my 60 ft gets better and I can drop my times.
RWDFTWBBQ
Just thinking about it, put it on a wheel aligner mark, pull the car down (Strapping the rear down only) until your tyres touch the guards. Then slowly release the straps until you're 30mm off the guards. Set camber to 0 degrees at this point.
You were previously squatting hard enough to touch the guards, you've now raised 40mm, so allow an extra 10mm for further squat.
See how you go.
a lot of this is going to depend on the front / rear coil over spring rates and how the shock holds / releases weight... if youre planning on playing with what you have then you will need to launch the f**k out of your car and make adjustments at both ends till you find a sweet spot for your set up till you cant go faster.. tyres will play a massive part too
^ yep, it's about how the actual shock behaves that you need to worry about more than this camber quest IMO.
Bilsteins in my two experiences with them, are not good for drag activities as they are quite hard and raising might not help all that much. If you go any higher the rear will be sitting even higher in the air and having the weight starting front heavy rather than at least even to transfer backwards.
My problem is that I purchased some R32 GTR rims with 255/50 16 M/T ET Streets which do not fit well inside the guards (I believe the cool kids call it hellaflush), when the tyre hook up it makes the outside edge of the guard hit the tyres, My conclusion to fix this for now (I will end up getting some 16 x 8 rims with a better offset) is to raise it up a bit to give it better clearance for now, I tried to overcome this initialy but fitting some standard shocks but although it got me to a better height the valving in the old stock shocks was arse.
Ive raised the front up one groove on the Bilstiens, which now has it at the heighest settings front and rear, I shall then lower the rear down one groove at a time over the next couple of weeks to try and find the sweet spot for the clearance I need.
ATM front is 345 and the rear (after some settling) is 370, as the Kings were progressive springs and the new ones are not so the squatting shouldnt be as aggressive due to the new springs not being as compliant in the first stage of compression..
The boat will go in for a wheel alignment on Monday to ensure Im on a level playing feel after all the playing around with the ride heights, Im going to get the camber set to 0.5 positive at the rear.
I will see how it goes on Wendsday night weather permitting.
Did a 11.6 at WSID, 0.3 faster than last time, best 60ft was 1.9, now its time to keep working on my RPM at launch to try and find the sweet spot, I never managed to find the right RPM tonight, 4000 wasnt enough but 4500 was to much.
Finding the happy medium is not such a easy process, for me anyway.
I did get to watch a S chassis 2ltr manual do a 9.? though, it was fast.
Didn't see you there last night.
Not sure on what method you used and I'm no expert but revs are one thing and how you release or slip the clutch is another. If you simply 'dump' the clutch at 4500rpm it will lead to wheelspin (in your case), but if you slip the clutch out it wont send all power straight to the wheels and allow a better take off. Just about practise really as its hard to get right.
I managed to get my 60 foot down from 2.4 first pass down to 1.8 on 15" 215 re-mould tyres on the same night (this was a few years back mind you).
1deg+ is a good thing. If you're running a street R33 GTST on 255 MT ET Street Radials with a 5-speed then you should be aiming for the high 1.5 - low 1.6sec 60ft region. What pressure do you have in the tyres?
I started at 17psi then went down 1 psi per run, best 60ft was at 14 psi, I went down to 12psi but my 60ft got worse, more likely my technique than the tyre pressure though..
Alot of my issues has to do with being consistant, trying to get my launch RPM, clutch slip, tyre pressures the same to get some usefull information is fairly tricky, with a heap more seat time and playing around with the settings should help me whittle my times down a bit by bit.
Thanks, Mark
Needs more Auto...
Thanks, Mark
Let me know next time you're heading out to race. If I'm around I'll poke my nose in and see if I can help.
Thanks mate, Im in the process of getting my Link ECU tuned up with launch control, hopefully that will make at least 1 thing easier, all I need to do is work on the other 300 things to do to get some good times.
I did manage a 1.604 on the 24th, most were around the 1.7 - 1.8 though.
Cheers, Mark
You need front shocks that are set up on a "90/10" ratio. I'm no expert on the matter but from what I understand the shocks draw out easily to transfer the weight to the rear wheels when launching. The shock then has a slow compression to help keep the weight on the back as you accelarate.
11.130 @ 130.45mph, 1.779 60ft
Camber was 0.5 deg positive with 0 toe
12 psi in the tyres
So far so good, only had 2 runs tonight as I blew a cooler hose near the turbo, it was to hot and to much bother to try and fix it there.
Next week Im hoping for even better.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
