  • Replies 59
Would this fit r33
Hey!
These are all multi-fit set-up's and have been fitted to a number of Skyline's incl. R33's.
Dimension wise they are identical to the 400LPH unit's they are just also E85 compatible.
Let me know,
Brendan
(VM)
  • 1 month later...
When switching over from or to e85 do u need to drop the tank and clean it or just fill up at empty?
Hi,
Always best to clean out the fuel tank, it's the NO.1 reason for fuel contamination of a fuel pump!
Cheers,
Brendan
(PEC)
  • 1 month later...
  • 4 months later...
Hi,
Cheers,
Brendan
(PEC)
Hi Brendan , I have a 460 on my car and a Haltech ECU and flex fuel Sensor and I am under the impression that once tuned for E85 and 98 pump , I can run any mixture from 0-100% of 98 or E85.
Maybe I have misunderstood how this will work, no mention of cleaning out the tank or fuel contamination. I was told that you could have any amount of 89 pump and fill it up with the E85 or visa versa ?
  • 3 weeks later...
Hey mate,
would this pump be suitable for an SR20? Currently it is running only 98 oct, but in the future I'll most likely run e85. Thinking that I'm looking to upgrade in the short time it might be a viable option.
Cheers.
Hey mate,
Cheers.
Hey,
These are all multi-fit set-ups so will fit all Jap cars!
It will take 98 octane as well as all common race fuels.
Cheers,
Brendan
(VM)
  • 8 months later...
  • 2 months later...
  • 2 months later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
