  • 3 weeks later...
Hey scotty what condition is the passenger rear like? Im after a cut section off rear quarter panel near rear tail lights. Ill send u a pick when i can so you know what im talking about.
Hi Scotty
Finally got the exhaust in the other week and have been enjoying it immensely, but sensibly so (not around Plod). Now I have a rear sway bar that ratlles madly ... the drop links are shot. What has this got in the way of a sway bar? And how much to the same address please? Thanks.
Hey scotty,
As i tried to explain before bout the rear quarter panel. I have attached a photo of section i need. From the spot ill need an inch front and 2 inches above and below. How much for this cut section mate
Hi Scotty
I have the stock bar and links, they should be fine but have you priced new ones?
Hey scotty,
I can cut it out if you want, but surely a good panel beater can fix that small ding? I would have thought it would be harder to weld in a section than repair that?
+1
I damaged my rear quarter panel (drivers side) in a similar area, panel beater fixed it fine.
Hi Scotty, You say the interior is ARX tan leather.
Do you have the interior light in the boot (including little metal clip things)? Also after the card holder under the driver's side sun visor as mine has a broken leg. PM me with prices etc if you have them.
Cheers,
Jidge
No idea sorry, all the interior is stuffed into the back as Craig was too slack to re-fit it all when he stole the black leather interior. I'm sure it is in there somewhere...
I don't think there were any mats, the rest of the parts are somewhere in the back. It looks like I will have to pull it all out some fine day and sort through all the parts people have asked for. Will let you know soon.
I know there is a cargo blind, and the door switch, not sure about the mats...
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
