  • Replies 43
Youtube Links.
Dropbox sucks for streaming.
I'm lost for idea's. Figured if it was a head gasket it would be constant smoke? Get worse with rpm's as pressure builds up? PCV valve cleaned, made 0 difference. Although it was gunked up and rattled when i shook it (think thats normal)
http://www.youtube.com/watch?v=UVU3XbimIsc
http://www.youtube.com/watch?v=G3aQ_biZaf0
Edited by Booki
Going to start taking it all apart tonight...just after i had put my sweet new -7's in :(
Anything else I should be changing while the head gasket is out?
Recommendation's on head gasket? (genuine, after market? Nismo? cometic?)
Edited by Booki
Just replace i with a standard gasket from Nissan. They aren't that expensive and are very good quality.
Get the cylinder head fully recoed while it's out. Valve regrind, stem seals, deck ect.
Get your injectors cleaned right before the head goes back on
Replace all the heater hoses
Still running stock injectors, worth spending the cash to get them cleaned?
Are there better options out their then the standard nissan gasket? While i would imagine they are good quality, I am planning on running 17-18psi boost on the -7's, would the standard gasket hold up? Or should i look at something after market?
Know any places that are reputable to get the head done? And rough costs involved?
Edited by Booki
We use stock gaskets in applications over 600hp and 30psi boost without issues.
If you do the job correctly, it will be fine
Anybody got any tips for taking the head off?
Both turbos are back out.
Cam gears and belt still on, looks like my cam timing is one or two notches out on the exhaust side...
Do people remove the head with the plenum attached? It looks like a bitch to remove the brackets hiding underneath the plenum.
Honestly surprised myself in how quick I was able to remove the turbos
Edited by Booki
Well for all those following, Heads off.
Now with the head out, I will send it off for a reco, though in the process their were some casualities. I ended up cracking it and just cutting a heater hose, and a two electrical connectors were damaged. Anybody know where to get a replacement heater hose and this particular electrical connector?
The other I am hoping to just open the connector, and solder/crimp it back down.
In the mean time I am hoping to get a neater engine bay setup, wanting to eliminate some hoses that are not required. Mostly the ones under the Plenum as they were a BITCH to get out!
Also, This wiring looks real dodgy and pox as, I don't think its standard/original wiring. Can anybody confirm? Then i will start following it up and eliminating it. Or at least making it neater.
Edited by Booki
Top hose in the pic that is broken - get it from Nissan (Usually the first place you should try)
The plug should be the same as Bosch 2 pin standard so I would try Repco etc for those. Pretty common plug. It won;t look the same but should still fit the Bosch 2 pin knock sensor.
The other wiring is anyone's guess
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
