However (and I am not imagining this) ->
After In had the rear brace installed the car is now very willingly going into a controlled oversteer/drift.
This was not the case before.
Also the rear feels less wobbly.
(I am still on the standard suspension)
I like to find out im wrong - let me know if you can come up with an explanation as to how this could be. Until then i'm going with GTSBoy's placebo explanation :)
I have heard many people say that the rear brace does nothing on an R33/34 and your explanation makes sense.... however have you seen the amount of extra strengthening and bracing in the rear of a GTR? All of this extra expense and weight added by the manufacturer for absolutely no gain or reason?
There are a lot of after market (including NISMO) rear braces and I find it difficult to believe that they were all developed cynically just to make money.
I would like to know the answer to this too
That was actually a point I was going to bring up.
Why would Nissan fit these when there is no added benefit?
I think you mean "no added TECHNICAL benefit". Of course, there could be a non-obvious technical benefit that i'm missing, or a non-technical benefit.
This post from SydneyKid is probably the most insightful (and what originally alerted me to the issue - was good to read it again): http://www.skylinesa...ost__p__4744778
  • 3 weeks later...
Well,
I now got the final word on this.
By pure chance I found two pages about removing and re-installing the (front) strut brace in my workshop manual.
It states:
Tightening the middle screw by a full turn!
If you don't believe it, I could upload a scan ...
As above. Pre-load not required or desirable.
That's hardly preload. 1 full turn is 1 thread is 1.5mm.
That's a little dismissive. Distance cant tell you load (force) directly, you need to take into account how stiff the loaded structure is. If the structure is flexible, the load will be low, if the structure is stiff the load will be high.
Any of those strut bars that have an adjuster in the middle are sufficiently flexy on their own that they'd bow up as you put that little bit of "preload" on them.
You don't even need to be an engineer to imagine how little force you'd need to apply to the adjuster to crank one turn into it once the slop had been taken up.
Yeah I see what you mean,
But a full turn on a thread/bolt can put up a significant force ranging into the tons.
(Also that was what I considered to be pre-load)
But my initial question is now answered by myself:)
You're supposed to tighten the bolt, so pulling the brace more together.
Also the manual states that the car has to be on an even surface, not jacked up when installing the brace.
I'm glad I did this right :)
If you were to do this jacked in the air I imagine that turn wouldn't be needed (or only half a turn). I find there is a tension difference on my front strut brace between on the ground and in the air.
  • 1 month later...
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
