Hello,
I've brought this up before with no solution, just wanted to try again. I've got a 2.5" catback exhaust with 2 resonators. There is a tiny muffler on the end of the exhaust,
my problem is that it still drones. Is it even possible to get a RB25de to have a clear sound without drone at all?
What are some people running on their Catback systems?
https://www.sau.com.au/forums/topic/411374-exhaust-sound-issue/
its the tiny muffler thats the issue, get a semi straight thru one,
my system has a hotdog resonator and a big oval muffler, the muffler is what muffles the drone the most, get a muffler thats semi striaight thru, so it curves inside, that will forces the gases to be muffled but not restricted , then your drone will come down ..
you need a either a large oval muffler or resonator .. police come straight after noisey cars..
Edited by SliverS2
are they hotdog resonators? thats odd because i have a 4L falcon with nothing but a large muffler on the back, and hardly any drone, sounds meaty actually. lol
Edited by SliverS2
doesnt look like much of a resonator, looks no better than a straight piece of pipe,
if it were me id have the big fat muffler on the back and an oval resonator, or id start there
WMDC5 is probably right, theres alot of honda's that sound like that,
a 2inch pipe size was probably better for the low power output too.
GL
hard to believe a good resonator and muffler wouldnt sound good without the drone, but i dont have an na, i know when i had a hotdog resonator with a cannon my car was extremely droning, i mean you got a headache after 5minutes
IMO whenever I have had just resonators that makes it drone. On my old motor na rb20 I had two hotdog style resonators sounded really nice under load but cruising it would be almost as loud and drone like crazy. Then I had the rear one replaced with an oval one and got rid of the drone almost completely, but made it sound not as good under load. Its a compromise really.
    • Yeah, you need to do it properly. You need to start out slow and gentle, ramping it up until they are good and hot, but not cooking, then roll off the other side (instead of letting them cool down quick).
    • I think yeah less hot fuel dumping into the top of the tank that wants to evaporate easily, fewer connections/hoses for permeation. Something like that. Also lower cost/easier production. Even my 2000 LS400/Celsior is a deadhead system. A single fuel hose to the fuel rails which have pulsation dampers attached and no return line.
    • I might do a few more high temp bed ins as described here.  I have a nice quiet 80kph road right near me.  How To Bed-In Your EBC Brakes For Street Or Track Use - EBC Brakes https://share.google/AjnOTILXoiqQnLu8p
    • I did a few 80-0 stomps. I then just rode the brakes while I applied throttle for a while to get them nice and hot. I live on a big hill and have been down it a few times also with stomps and brake riding.
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
