Honestly, if you are sick of the sound I know where your coming from, thats why I changed mine
And it doesnt really matter what you choose as long as its a plumback, there are to many issues with the Atmo BOV's (Search and you will find) so make sure you get a plumback
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579403
Yea Cal, pretty over it, its a bit boring i guess lol
I have heard about a few good read ups on the Gtr ones so might give one a go.
And remember dude the coast is still pretty hostile with the boys in blue so keep it legal :thumbsup:
Maybe see you on Sunday?
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579462
are the stock ones good enought for gt30's? must be alot of air to move for the blow off valve.
when i back off the throttle im getting a quietish zututututu...
Edited by SliverS2
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579473
Mine failed a long time ago, it was sticking open and not getting boost etc..... Not commen from what ive seen but made a big difference when i put the new plumback on and got some zutututu action too :P
Yep ur not wrong Mat, thats why im trying to keep things looking stockish i guess ha
Yea man possibly, i will let u no during the week for sure, cheers
Yeah good plan, keep out of trouble!
Let me know if you can come say G'day and meet some of the members even if you cant make the run :)
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579484
AFAIK the stock BOV works fine on most Gt30 series turbos, plenty of people running GT3076's etc with stock/GTR bov's
Mine is a Greddy Type RS Rip off, but im Considering getting a genuine. So if that happens I will probably sell mine which has a custom plumback adapter on it (as the genuine one doesnt fit and the rip off doesn't come with one)
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579490
Haha im hoping so. Yeah man for sure im pretty keen, hopefully install my coilovers this week, would be sweet to give em a run
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579535
I think its the pressure that is a concern for them sealing, and they do flutter to a degree so its obviously a lot of air but alse depends on the position, factory position is pretty good as its close to the TB, the GFB one i have now still flutters a bit even on soft setting, but its a LONG way from the TB.....
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579536
Mine went on on the weekend, have a look -
http://www.skylinesaustralia.com/forums/topic/358438-34geeteetee-daily-track-project/page__st__400
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579537
Thansk mate, if you dont make this cruise dont worry as we plan on doing stuff at least monthly! November will be an exception as a couple of us are entered in the SAU Nats :D
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579547
Sweeeeet, sounds good man!
If you join as a member there is a members section with a Newy/Coast chat thread where questions like these will be answered by the guys for ya :D
Plus for the price of membership you get a heap of value, stickers, lanyard, shirt and discounts off purchases at some places AND it give you better pricing for events etc :yes:
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579557
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
